[archived] 0.8.X images from ayufan; Mate DE + video / 3d acceleration
#21
(04-27-2019, 03:03 PM)Diesel141 Wrote: Bu dağınık Mate masaüstünü seviyorum. FAN dışında her şey harika çalışıyor. FAN çalışmıyorken CPU çok ısınır. Yazılım güncelleyicisini çalıştırdım. Hala çalışan FAN yok. Gerçekten bu işletim sistemini kullanmaya devam etmek istiyorum. Birisi FAN için bir fikriniz var mı? https://github.com/tuxd3v/ats
Ben yüklü  biyonik-mate-rockpro64-0.8.0rc10-1125-armhf.img.xz.
https://forum.pine64.org/showthread.php?tid=6489
#22
Thanks. I will give it a shot. I've learned a lot today.
Edit: Well the tool code all ran with no errors. The FAN still not working. Fan runs on Android the moment it starts booting. So I know my fan will work. I give up.
#23
(04-27-2019, 04:15 PM)Diesel141 Wrote: Thanks. I will give it a shot. I've learned a lot today.
Same here, im guessing it has to do with instructions stating that it was made for a specific Kernell, one that doesnt give the benefits that newer builds have. There is a build guide somewhere in forum just havent bothered since really builds are still not ready for my use case scenario, witch is media so many people dont bother to address issues like this till they now they will stick to a build.
#24
I will try to research the problem some more and post here if I have any luck.
#25
"ATS - Active Thermal Service" does not work if you changed the original language.
I am installing "ATS - Active Thermal Service" for Ayufan and then changing the language.
#26
(04-27-2019, 04:15 PM)Diesel141 Wrote: ... The  FAN still not working. Fan runs on Android the moment it starts booting. So I know my fan will work. I give up.
A simple way I get a fan working on my rockpro with one of these images:
    echo "255" > /sys/class/hwmon/hwmon0/pwm1
with the number between 0 (off) and 255 (max)
#27
#28
Great news. I successfully installed Active Thermal Service!! I have a working fan!
#29
Is video over Displayport supported, or only HDMI?
For daily driver it would be necessary for many of us to be able to use dual monitors..
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,336 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,153 04-23-2023, 01:32 PM
Last Post: diederik
  RockPro64 linux console video mode callegar 0 892 09-06-2022, 02:32 PM
Last Post: callegar
  Armbian images available Luke 60 87,995 08-04-2022, 06:56 AM
Last Post: Rocklobster
  Video playback hiccups with Fedora 35 on RockPro64 whitecat23 4 3,635 02-01-2022, 03:35 PM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,468 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  ayufan kernel update unbootable TheHunter 2 3,201 03-12-2021, 05:17 PM
Last Post: LMM
Question Ayufan RockPro64 updates? hemertje 3 6,231 10-22-2020, 01:16 PM
Last Post: dukla2000
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 5,377 10-22-2020, 01:12 PM
  Slow/dead ethernet on (non-Ayufan) Linux Mainline (fixed) mmatyas 1 3,572 04-17-2020, 02:53 AM
Last Post: Thra11
