Problems with booting
Hi, so I finally got my rockpro64 with display. Problem is that when I try to boot android image from sd card (Image is 7.1.2. for sd Cards) i don't get anything on screen. I can feel my board getting hot, I have powered it by 12v 5A power supply. Also, whenever I push buttons board reacts. I can see ethernet port LED's flashing or turning off if button is pressed for some time. LED near buttons start flashing when RESET is pushed. But screen doesn't show anything. I got it to show something once, but it disapeard qucikly thanks for your help!
Found another topic which looks like a other fellow member has a same problem. https://forum.pine64.org/showthread.php?tid=6438 I did comment there but it looks like an old topic and doubt anyone will reply there. Solution to problem isn't there also.
  Booting my RockPro64 from NVMe drive PsySc0rpi0n 4 10,682 05-11-2022, 02:35 PM
Last Post: PsySc0rpi0n
  Sata HD stopped booting db579 2 5,470 03-11-2022, 03:34 PM
Last Post: db579
  Troubleshooting RockPro64 + Roshambo case SSD problems necoc.yaotl 1 5,195 11-30-2020, 11:10 PM
Last Post: necoc.yaotl
Exclamation need help booting off USB 3.0 HDD/SSD idontgetit 1 6,023 10-29-2020, 04:50 AM
Last Post: t4_4t
  Rockpro64 with PCI FC Card - Not booting (Sometimes) MSteam 1 5,038 10-25-2020, 07:42 PM
Last Post: MSteam
  RockPro64 not booting jekohk 10 21,117 06-09-2019, 01:53 PM
Last Post: Davidos
  Hardware issue overheating while booting and fail to boot DIDquest 13 27,436 03-23-2019, 02:50 AM
Last Post: nJoy.
  EMMC not booting while SD does. Apokalypz 29 54,171 03-10-2019, 04:12 AM
Last Post: graham-r
