PhoenixCard Burning Error
I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times
(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times
We start release Android, Remix and Linux build images that can be burned by DD method.
Did you check your card?
See:
http://forum.pine64.org/showthread.php?pid=6097#pid6097
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
Where can i find instructions for the DD method?
Already posted at http://wiki.pine64.org/index.php/Pine_A6...re_Release.
We plan to make this page better understandable on next few days.
It says to use phoenixcard for Remix OS. Also I couldn't find the DD method, which tab is it under?
Hi, have you tried Linux Live USB Creator ? http://www.linuxliveusb.com/downloads/?stable
(04-22-2016, 12:12 AM)tllim Wrote: We start release Android, Remix and Linux build images that can be burned by DD method.
I tried the linux live usb creator and it just gave me error messages part way through
(04-22-2016, 02:22 PM)alin123 Wrote: Where can i find instructions for the DD method?
OK, make sure you not got a counterfeit SD card. For me I had the same error but I retry few times and format my card in Fat32 with Minitool Partition  and i works ! So try and tell me
Have a nice day
Cookeys
http://forum.pine64.org/showthread.php?tid=548
You could try this. Had to do the plug-out->plug-in method for my burns as well, but it works quite reliably. You probably don't need to reset the partitions, just burn, wait for error, leave Phoenixcard running, reinsert the card and burn again.
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 6,860 04-19-2019, 08:26 AM
Last Post: psychedup
