GPIO in sleep mode
I want to do a fade in and out of an LED while the board is in sleep mode.  I can easily do this in arduino, but would rather have the rockpro64 do it.  Is there anything the rockpro64 can do while asleep aside from wait for a signal to wake it up?
There is a 4 Pin JST Connector just behind the Power DC Jack .... its directly connected to the power rail ... you could rig a simple circuit up completely independent of the GPIO using a 555 Timer some resistors, a tranny and and capacitors etc even safer install your own buck converted to drop the voltage down to be even saver. But I take it you wanted GPIO / PWM to avoid the complicated electronics !
I want to leave that connector alone as it's meant to share power with the 2 hard drives I have connected to it. I'd like not to mess with that.
  using spi and gpio nano2 0 2,661 07-09-2024, 07:16 PM
Last Post: nano2
  External Touchscreen via DP-Alt Mode soloquintett 0 2,900 05-01-2023, 12:29 PM
Last Post: soloquintett
  GPIO on the RockPro64 - all pins high? colinmarc 2 5,927 11-18-2022, 10:20 AM
Last Post: colinmarc
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 13,953 07-18-2022, 10:05 PM
Last Post: zer0sig
  Using GPIO interrupts antonlyap 3 7,270 06-30-2021, 01:32 PM
Last Post: antonlyap
  GPIO performance 100x slower compared to Raspberry Pi 3 axelf 9 17,477 08-19-2020, 04:41 PM
Last Post: Gienek
  Make SD Card to read-only mode rahulsharma 1 3,828 11-04-2019, 11:42 AM
Last Post: Nikolay_Po
