I have a ping64+ 1Gb that refuses to obtain a IP address.
ip addr:
Doing a sudo ifconfig eth0 down && sudo ifconfig eth0 up results in:
Edit:
Output from: systemctl status NetworkManager-wait-online.service
I also attached the serial out from the first boot.
I have also tried to manually set a mac address. That does not seem to change anything. I could be doing it wrong.
Edit:
It does look like I am using the provided mac address:
Any suggestions welcomed.
ip addr:
Quote:1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 26:6f:b5:31:80:36 brd ff:ff:ff:ff:ff:ff
inet6 fe80::246f:b5ff:fe31:8036/64 scope link
3: sit0: <NOARP> mtu 1480 qdisc noop state DOWN group default
link/sit 0.0.0.0 brd 0.0.0.0
Quote:[ 5060.383772] Call trace:
[ 5060.592128] Call trace:
Edit:
Quote:NetworkManager-wait-online.service - Network Manager Wait Online
Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabl
Active: failed (Result: exit-code) since Thu 2018-08-23 15:00:12 UTC; 20s ago
Docs: man:nm-online(1)
Process: 999 ExecStart=/usr/bin/nm-online -s -q --timeout=30 (code=exited, sta
Main PID: 999 (code=exited, status=1/FAILURE)
Aug 23 14:59:42 pine64 systemd[1]: Starting Network Manager Wait Online...
Aug 23 15:00:12 pine64 systemd[1]: NetworkManager-wait-online.service: Main proc
Aug 23 15:00:12 pine64 systemd[1]: Failed to start Network Manager Wait Online.
Aug 23 15:00:12 pine64 systemd[1]: NetworkManager-wait-online.service: Unit ente
Aug 23 15:00:12 pine64 systemd[1]: NetworkManager-wait-online.service: Failed wi
Edit:
Quote:eth0 Link encap:Ethernet HWaddr 00:06:dc:8b:41:a5
inet6 addr: fe80::206:dcff:fe8b:41a5/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3 errors:0 dropped:0 overruns:0 frame:0
TX packets:15 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:401 (401.0 B) TX bytes:2462 (2.4 KB)
Interrupt:114
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:80 errors:0 dropped:0 overruns:0 frame:0
TX packets:80 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:6368 (6.3 KB) TX bytes:6368 (6.3 KB)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
