apt --fix-broken install
rock64@rock64:~/Downloads/sdrangel/build$ sudo apt-get install dkms
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 libgl1-mesa-dev : Depends: libglvnd-dev but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
im just a bit over my head in dealing with this .....
i would love suggestions ....
also need to install Qt5
im trying ...
rock64@rock64:~$ sudo apt -f --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libpipeline1 libpython-stdlib man-db python-minimal python2.7
python2.7-minimal
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libglvnd-dev
The following NEW packages will be installed:
libglvnd-dev
0 upgraded, 1 newly installed, 0 to remove and 7 not upgraded.
63 not fully installed or removed.
Need to get 0 B/3412 B of archives.
After this operation, 25.6 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 87314 files and directories currently installed.)
Preparing to unpack .../libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb ...
Unpacking libglvnd-dev:arm64 (1.0.0-2ubuntu2.2) ...
dpkg: error processing archive /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_arm64.deb (--unpack):
trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so', which is also in package libmali-rk-utgard-450-r7p0:arm64 1.6-1ayufan10
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
rock64@rock64:~$
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,416 10-12-2023, 05:14 PM
Last Post: tpaul
  Managed to install Kubernetes digitaldaz 3 4,296 08-16-2022, 02:44 AM
Last Post: mmarkgilbert
  How Can Install Unify controller in rock64? gedas07 0 1,851 03-23-2020, 08:41 AM
Last Post: gedas07
  Can Anyone help me install Wine latest on Rock64 Rock90 1 3,094 08-10-2019, 06:18 AM
Last Post: OnyxxOr
  HELP I want install a desktop but I don't Know how can I do gedas07 11 12,991 10-02-2018, 01:34 PM
Last Post: jovval
  rtl8812au driver install.. 11b2p508 11 16,381 05-20-2018, 01:36 AM
Last Post: brajul
  4.4.120-gac51b70a-dirty works, 4.4.126-g6dc34509-dirty seems broken cooker 0 1,560 05-07-2018, 08:54 AM
Last Post: cooker
  bringing up X on minimal stretch install gene83 11 12,032 03-05-2018, 01:47 AM
Last Post: jegb
  Explore the Kernel make install secret cooker 3 4,451 02-27-2018, 09:16 AM
Last Post: cooker
  Cant'n install x11 on debian stretch Chris66 5 6,364 01-28-2018, 09:06 AM
Last Post: Chris66
