HOW TO - Connect the serial console
#21
I've bought a ch340 uart converter from pine shop, it looks exactly like the one on the picture. But when I put the yellow jumper on 3v3, i get nothing in dmesg, only when I put the jumper on 5V I get USB device recognized in dmesg and the ttyUSB port is there, but then,, of course, I don't get anything on it since it is on 5V
This is on 5V
# dmesg | tail -f
[98293.116166] usb 3-1: new full-speed USB device number 3 using uhci_hcd
[98293.304184] usb 3-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
[98293.304187] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[98293.304190] usb 3-1: Product: USB2.0-Serial
[98293.307329] ch341 3-1:1.0: ch341-uart converter detected
[98293.314267] usb 3-1: ch341-uart converter now attached to ttyUSB0
this is on 3V3
nothing, nada, zilch Wink
any ideas? is my ch341 dead? My PC too old?
Hi all,
Three weeks ago, the RockPro64 kit and serial connector arrived. I tried to run the Debian installer, I could see the console output and failed to enter anything.
I connected the PIN 10 when the installer menu was shown, but the console simply did NOT accept any input.
Any idea what went wrong ?
Thank you,
John
(05-06-2022, 06:44 AM)aivanise Wrote: I've bought a ch340 uart converter from pine shop, it looks exactly like the one on the picture. But when I put the yellow jumper on 3v3, i get nothing in dmesg, only when I put the jumper on 5V I get USB device recognized in dmesg and the ttyUSB port is there, but then,, of course, I don't get anything on it since it is on 5V
This is on 5V
# dmesg | tail -f
this is on 3V3
You're not alone !
I bought one from the store last month, and I have the same issue.
The converter's LED lights up red when I plug it in 3.3V, but dmesg/lsusb remain silent. Tried with Linux kernel versions 5.15.0 (ubuntu 22.04) and 5.15.8 (manually compiled).
So far, I only get messages in dmesg output with 5V mode enabled.
I believe my serial-USB adapter does not support high baud rate as well. This is what I did to change the baud rate on the Debian Installer:
  • mount the sd card on your main machine and append this line at the end of /extlinux/extlinux.conf
    APPEND ${cbootargs} console=ttyS2,115200
  • now you can screen /dev/ttyUSB0whatever 115200
  • when the ncurses interface started I got gibberish characters (some issue with encoding I guess). To fix that just exit screen (ctrl+a then k then y) and launch screen again. To update the interface I suggest typing (with tx attached of course) something like arrows
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,231 10-23-2020, 11:56 AM
Last Post: hmuller
