Intermittent PSU Connection
Hi all
Just received my RockPro64 and high power PSU from Pine64 shop. The PSU connection between the barrel connector on the PSU lead and the barrel connector on the RockPro64 board seems really intermittent on mine - with it proving very tricky to get the green power LED to stay on and boot to start. I have managed it a couple of times but it's really tricky.
Am I doing something obviously wrong?
Have raised a support ticket with Pine 64 - but thought I'd ask around here if there were any known issues?
(07-23-2018, 10:16 AM)noggin Wrote: Hi all
There's something wrong with the connector on the PSU or on the board, mine does exactly the same thing. Rotate the PSU barrel in the socket until the green light comes on and then *don't touch it* or you'll cut power.
High quality QA right here folks.
If there is any vertical pressure on my power connector the power is interrupted. Just a tiny amount of pressure from the tension in the cable will do this. This makes the board effectively unusable.
It's taking a while to resolve via the support ticket system, my last update with requested information remains un-answered after 5 days...
Customer support have asked me to return my RockPro64 and my PSU - which I've done. Fingers crossed for a speedy RMA process.
  Connection 2k LCD displays over MIPI AI_newsettler 1 2,941 11-06-2018, 07:54 AM
Last Post: FancyPBJ
  WiFi/BT, How to make a connection? Aesop 0 2,644 09-27-2018, 11:07 PM
Last Post: Aesop
