[SOLVED] stuck at emmc
(04-29-2018, 11:59 AM)dr_dre Wrote: yes i used a FTDI232 to do the job .
https://www.aliexpress.com/item/Free-Shi...0.0.ITatop
Ah, from your print log, it looks like your SPI Flash was corrupt. And you've since worked out how to disable the SPI flash (my apologies, I was talking about the eMMC jumper before, I missed the reference to SPI flash ;0 during boot by grounding the output from it (connecting 21 to 20)... reminds me, I have to check, 23 -> 25 *should* work also, and means you can use a standard jumper then also! Smile Did you just erase the SPI? As you can still boot from SD and eMMC if the bootloader has been written to SPI, it just doesn't work well if it's corrupt!
And btw, have a look for "Serial console cable" if you want to make your life a bit easier... it plugs directly in to the rock64 headers with no need for extra leads or exposed circuit boards. Wink
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,071 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,976 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,723 08-19-2021, 06:46 PM
Last Post: bcnaz
  Rock64 No Audio - Solved wbecks 12 30,161 08-13-2021, 01:23 PM
Last Post: blakeadam
  Segfault with GCC in Armbian [Solved]. ejolson 13 18,601 07-07-2021, 10:16 AM
Last Post: stelabentley
  Receiving errors about eMMC (?) acasta 11 15,880 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 29,140 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 105,649 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 2,283 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 3,683 06-25-2018, 03:20 AM
Last Post: Auggoncalves
