Video calibration pattern generator
I would like to build a video pattern generator for calibration of TVs. One item of importance id the capability of outputting HDR10 images. I haven't been able to find any information on OS software and or application programming to do so. I know that the Rock64 is capable of outputting HDR10 metadata, but how to do so and what software is supported is unknown. Does anyone have any leads in this regard?
Thank You in advamce.
Static HDR/HLG is supported in 4k but only @30FPS until some problems will be solved in rockchip kernel code (no documentation available for this). I do not known application that fulfill your exact needs. Probably you can write some code Smile Check this and continue here. You need only DRM part and not MPP part.
  1. initialize and check parameters of DRM
  2. choose size and position manually (not from mpp decoded frame)
  3. allocate one (or more) DRM buffer and register as framebuffer (fb_id) (choose 10-bit format)
  4. map DRM buffer to memory and render your test pattern
  5. set manually (not from mpp decoded frame) static HDR or HDR/HLG metadata (EOTF+COLOR_SPACE+HDR_SOURCE_METADATA) and switch DRM buffer (fb_id) to output
Happy hacking !
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
  doesn't boot, no video cjyar 7 8,173 11-15-2019, 03:45 PM
Last Post: ab1jx
  Rock64 for video surveillance martinschm 6 7,088 09-19-2019, 01:56 AM
Last Post: Jozek
  ROCK64 RK3328 state of 4K (and FHD) video playback in FBdev kroko 3 4,468 03-31-2019, 11:43 AM
Last Post: kroko
  Video playback performance va88 0 2,110 12-19-2018, 01:19 PM
Last Post: va88
Question Need help on 4K Video playback leonqin 4 6,495 08-19-2018, 06:49 AM
Last Post: soerenderfor
  4K HDR Video GeerGuy 5 7,280 05-02-2018, 02:43 PM
Last Post: mcerveny
  My new video about the Rock64 NicoD 2 3,563 04-06-2018, 12:08 PM
Last Post: el.librero1800
Sad Rock 64 No video borisacomputers 4 5,505 03-03-2018, 03:11 PM
Last Post: borisacomputers
  trouble with video playback MaWalla 8 10,108 01-01-2018, 09:41 AM
Last Post: Lalith
  Newbie question - should a Rock64 with no mmc card still output some video ? sgk 6 8,129 10-14-2017, 08:16 PM
Last Post: fusionneur
