Help needed - installing Parrot OS on PINE A64+2GB Board
Should I image the SD card with the FAT32 format or what other format?
Does Parrot OS support non HD resolutions? I ask because I only own an old SVGA monitor and a projector that also doesn't support HD resolution. I happen to have a HDMI to SVGA adapter, which I use with my Rpi 2 running Parrot Sec OS without a problem, but my experience with PINE A64+2GB Board has been totally different, since I haven't been able to even make it work.
(03-05-2018, 12:56 AM)Doryan Wrote: Help needed - installing Parrot OS on PINE A64+2GB Board
Write any image for sd cad no need setting format from yourself just only download Etcher to burn your sd card can work it.
https://etcher.io/
The hdmi to svga seem is not work .
http://wiki.pine64.org/index.php/Pine64#...structions
see to Plug in the HDMI Cable, Ethernet Cable and Peripherals
And Don't know Parrot OS used from who kernel and what version to build this image  , if ( ayufan ) new image
/boot/uEnv.txt can edit resolution but i haven't to try edit it svga will work or not .
You can easily to find out your image is it work .
1.  Because i don't know Parrot OS the SSH have enable or disable .
If you can login from SSH this means the image not problem only the hdmi to svga can't support or you haven't edit /boot/uEnv.txt .
2. And use ipscan tool can find out your parrot os ip addr , if can find it the kernel is already running .............
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
Wink Volumio 3 Pine A64+ unofficial shinzuka 6 1,659 05-28-2026, 02:13 PM
  Open Media Vault - Help needed janeku 3 10,381 04-01-2021, 06:36 AM
  Pine A64+ mainline mipi-dsi Learnincurve 3 11,592 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 15,147 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 9,899 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 23,015 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 34,713 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 11,135 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 10,162 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 9,403 05-09-2019, 05:42 PM
