I want to change the resolution of the monitor.
Google Translate :
But /boot/config.txt does not exist. How do I change it?
(02-28-2018, 03:38 AM)pine3228 Wrote: Google Translate :
You can edit /boot/efi/extlinux/extlinux.conf and put drm_kms_helper.edid_firmware=edid/1920x1080.bin at the end of the append line.
The resolution did not change
(02-28-2018, 07:20 AM)pine3228 Wrote: The resolution did not change
What resolution did you want? The example I gave is for 1080p
The resolution of my monitor is 1600 x 900
(02-28-2018, 11:32 PM)pine3228 Wrote: The resolution of my monitor is 1600 x 900
I found the following post on google...
https://forums.gentoo.org/viewtopic-t-97...art-0.html
  Wrong resolution and very slow start of wifi. jgpacc 2 3,777 01-11-2022, 03:55 AM
Last Post: alanwake82
  Change Mac address on Linux fahr 3 4,648 08-07-2019, 03:31 AM
Last Post: AlexS
Photo HDMI resolution bueschi 0 2,152 01-06-2019, 02:34 PM
Last Post: bueschi
  Monitor Rock64 serial console with PineA64 MarkHaysHarris777 7 15,649 09-09-2017, 04:35 PM
Last Post: MarkHaysHarris777
