USB HDD and Android TV
I've had my Rock64 4GB board about a week.  My primary use will be as an android TV box.  My problem is that my USB hard drive doesn't work when attached to any USB port.
The drive is a western digital 3TB USB2.0 drive, model WDBAAU0030HBK.  It is externally powered and formatted in NTFS, so it shows up as 2TB.
When I try to access it in ES explorer it says "Operation Failed".  It does not show up when I try to access it through VLC.  The drive works when attached to my windows PC, my smart TV and my Roku.
I am using Android TV Image "android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz"
Any suggestions are welcome, as this is one of the main reasons I bought the board, to play videos from my USB HD on my smart TV through the Rock64
(02-15-2018, 07:38 PM)JeffsNetflixPassword Wrote: I've had my Rock64 4GB board about a week.  My primary use will be as an android TV box.  My problem is that my USB hard drive doesn't work when attached to any USB port.
I had the same problem with a 2TB usb3 hdd, worked fine attached to my laptop but refused to work when plugged in to the r64, I switched it to a different USB enclosure and it worked just fine.
I'm not sure, performance wise, that NTFS is the best option. With USB booting now working, it's simpler to just flash a sdcard image to the hdd and boot from it.
I should add, I'm booting from EMMC, 16GB. I have a 32GB usb thumb drive that works fine. Yesterday the r64 did recognize the 2TB drive in ES explorer and I watched some videos just fine. Today it refuses to recognize it again. The drive is all one unit, the case is integral, so I can't change cases. There has to be a solution to this. Thanks
  Download IDB fail when trying to flash Android image cherkasoff 0 4,354 04-05-2020, 07:41 AM
Last Post: cherkasoff
  How to get UHD 4k working (with Android TV 7) Hotkey 7 8,580 09-18-2018, 09:39 AM
Last Post: Trash_Can_Man
  AOSP Build Steps Using github.com/ayufan-rock64/android-7.1 birender.s 15 20,499 05-09-2018, 01:20 AM
Last Post: burram
  Some questions about r64 and ayufan android tv Synthetikz 1 2,748 03-13-2018, 03:28 PM
Last Post: Luke
  Unable to flash Android TV on eMMC: rkflashtool error fbossi 3 5,168 02-02-2018, 08:37 AM
Last Post: dannyboyw
  Root Android TV totalgaara 6 8,458 12-21-2017, 02:51 PM
Last Post: totalgaara
