RockPro64 and Pine H64 Discussion Thread
#41
(03-06-2018, 04:59 AM)LINUX_YY Wrote: wanna order RockPro64... when will be released and where to order?
We have push the Rockpro64 schedule to April time frame incorporating one new feature. When Rockpro64 available, to order, we will publish at PINE64 store.
#42
What new feature?
Sent from my VS986 using Tapatalk
#43
(02-24-2018, 01:10 AM)Tigger Wrote: What USB version is used to implement the Type-C port, or is its sole purpose to provide the DP signal ?
If USB is implemented behind the Type-C port does using it, with USB devices, sacrifice any of the other USB ports ?
Is USB Power Delivery implemented at all behind the type-C port?
The USB type C port for both USB 3.0 function and also DP signal. No other USB port been sacrificed. There is no USB power delivery behind the type-C port due to Rockpro64 require 12V supply due to PCIe bus.
#44
What new feature?
You will find out on April.
#45
What new feature?
Is there still no plan for an audio DAC add on for the RockPro?
#46
What new feature?
Focus on the Rockpro64 board release first.
#47
(02-21-2018, 11:53 PM)tllim Wrote:
(02-21-2018, 03:56 PM)Nelly Wrote: What are the improvements of rockpro64 over rock64? Worth upgrading if just using as media player or no?
Rockpro64 has more powerful CPU and GPU. However, for media player and NAS area, just stay with ROCK64.
Hi TL, I'm very happy about my Rock64 NAS setup equipped with a 2-bay USB 3.0 dock and 2 HDDs sitting on it. However, the bandwidth is bottleneck by single USB 3.0 which the speed will split in half when 2 HDDs using at the same time.
Q is, will Pine H64 equipped with mini PCIe to 2 sata card performs better for a 2 bay nas use, like supporting 2 native sata and their speed under Openmediavault? Is it worthy to update H64 from Rock 64? Will either RockPro64 or H64 support one or two SATA or USB expansion cards in long run?
Much appreciated for your read and answer.
Cheers,
David
#48
Cheers,
David
Its 4 lanes so that is 4x500MB/s raw transfer which bottleneck 4x fast SSD but would be fine with x2.
I have forgot what the encoding overhead for Sata and PCI-e lane is but some mirky mem says 20% so buy 400MB/s SSDs and your on a 4 way winner with a 4 lane x4 pci-e sata card I guess.
Thats unusual it is 20% http://www.tested.com/tech/457440-theore...underbolt/
#49
(03-09-2018, 09:55 PM)tllim Wrote: The USB type C port for both USB 3.0 function and also DP signal. No other USB port been sacrificed. There is no USB power delivery behind the type-C port due to Rockpro64 require 12V supply due to PCIe bus.
Thanks. Too bad about the power delivery. I had hoped to supply the board with power through the type-c port. Now it’s another USB port to me.
#50
Cheers,
David
Very interesting read and very clear from theatrical part. Thank you.
The bandwidth are enough for 2 HDDs or maybe 4 bays running raid 10 or free of any raid. Expecting really hardware testing based on H64 testing.
Further consideration on driver part is, wishing H64 support an imexpansive mini pcie to 2 sata adapter, see adapter link https://www.ebay.com.au/itm/Mini-PCIe-PC...SwqfNXoFK0
Or using Rock 64 equiped with pcie to 4 channel 4 port sata to form a 4 HDDs array. See adapter link: https://www.amazon.com/Vantec-Channel-4-...Bpcie&th=1
It has to be cheap since these day 4 bay nas has a very compatible price, e.g. QNAP TS-431P 4 bay nas. Wish my hope can come true.
  Shipping Update and Stock Availability Thread Luke 87 90,858 03-05-2023, 12:35 PM
Last Post: maos
  PinePhone BE & Pinebook Pro shipping update thread Luke 136 168,679 06-04-2021, 09:43 AM
Last Post: Luke
  PinePhone Mobian CE shipping update thread Luke 59 81,818 04-25-2021, 12:57 PM
Last Post: Luke
  PinePhone KDE Community Edition shipping update thread. Luke 135 178,398 04-11-2021, 01:47 PM
Last Post: Luke
  Manjaro Community Edition Shipping thread Luke 122 149,189 01-28-2021, 07:30 PM
Last Post: Muad
  December Community News Discussion Luke 2 7,581 01-19-2021, 04:48 PM
Last Post: zer0sig
Information August/ September Pinebook Pro, PineTab and PinePhone shipping thread Luke 256 378,359 10-27-2020, 11:14 AM
Last Post: Luke
  New Pine Store is up! Luke 17 30,789 10-12-2020, 04:28 PM
Last Post: zer0sig
  Pine Tab Markdanni123 3 6,238 10-04-2020, 11:26 PM
Last Post: zer0sig
  September Pine phone sales ? bcnaz 5 9,385 09-26-2020, 01:36 AM
Last Post: bcnaz
