flash image directly to eMMC?
It´s the first time that I use a eMMC module, and I have one question. I have bought the USB adapter for eMMC module (https://www.pine64.org/?product=usb-adap...mmc-module), and I have tested that is possible to flash images to the USB with the eMMC module. My question is if it's possible to flash an image direcly to the USB and the connect the eMMC module to the ROCK64 to boot, or if it's necesary to do the process with the sdcard and the jumper. if not, what is the reason?
Thank you in advance,
Gregorio Martinez.
be sure that the image you burn to emmc is for the emmc and not a sd card image or a sd card to emmc image. and, yes, if it is proper image you can use adapter to burn to emmc.
Hmm... I'm waiting to get my first Rock64, I thought I could just do as the op says and flash a sd card image to the emmc. If I look here practically all images says either "microSD Boot" or "microSD to eMMC", so I guess they aren't useful then. Where do I find images that are made for emmc?
on that page you linked although for some reason they are only offered for android. perhaps pine64 rotated away from letting people do their own flashing for some reason. maybe if you ask they can get you whatever it is you want.
(01-07-2018, 06:55 PM)gmruiz Wrote: Hello,
Gregorio Martinez.
You can flash any of ayufan's Linux images directly using the USB ->eMMC adaptor and boot from eMMC. As for android, you can  flash the RAW images using the adaptor.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,071 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,976 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,724 08-19-2021, 06:46 PM
Last Post: bcnaz
  Got an error message when trying to flash the Rock64 OS ilan 0 2,064 06-29-2020, 04:53 PM
Last Post: ilan
  Download IDB fail when trying to flash Android image cherkasoff 0 4,326 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 15,893 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 29,152 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 105,701 02-06-2019, 04:02 PM
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 2,020 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 2,283 02-04-2019, 07:36 AM
Last Post: LMM
