Archive of past Rock64 Linux Images?
Is there an archive of past community Rock64 Linux images?   Current releases of Ayufan seem to have incomplete audio support with no apparent way to direct audio output from the internal 3.5 mm headphone (A/V) jack.   There was a community SD card Linux image that I don't believe was Ayufan, that did support audio from the headphone jack dating back to the late October or November 2017 time frame.
Current Ayufan images do produce HDMI audio but nothing from the 3.5 mm A/V (headphone) jack.   I would appreciate any help with gaining access to back archives or help to configure audio on the headphone jack.
Thank you,
Bill, WA8WG
https://github.com/ayufan-rock64/linux-build/releases/
http://wiki.pine64.org/index.php/ROCK64_...re_Release
Thank you.  I have checked out past releases of ayufan on GitHub but didn't find the image I had loaded that did support audio output from the headphone jack.   I don't exactly remember the particulars, but do recall that the default image login was not the usual rock64/rock64 as is the case with the ayufan Debian images.
Were there past Rock64 images in the community that were not ayufan?
Bill
you might want to check the armbian images for rock64. i think they have an 11/20/17 or so image.
https://dl.armbian.com/rock64/
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 304 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,388 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,726 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,196 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 347 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,919 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,547 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,122 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 767 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 964 10-07-2022, 07:50 PM
Last Post: rookie_267
