is the power indicator suppose to be blinking?
Hi, i plugged in power, but its blinking.. is this normal?
first time plugged into power
(11-20-2017, 08:59 PM)finae Wrote: Hi, i plugged in power, but its blinking.. is this normal?
Which LEDs are you referring to ?
I'd assume the green power LED on the SBC, but you know what they say about assuming anything!
You'd assume correctly. What PSU / Power cord are you using ?
I m using one from pine64.org, 5v3a
initially all 3 led blinks
stats, pwer, and dc-in
today only the dc-in is blinking
this is with and without any sd/emmc plugged in.
so i m at a lost for word..
i received the board on 0ct 13, foudn i need power, so check locally and none car 5v3a (the 3a output was the problem, none carry here and highest i see for 5v is 1.2a)
i order one on oct 21, it just came last night.
using pine installer, etcher - for the sd card with image for debian and android stock 7.12, both does nothing (initially all 3 lights blinks - this is after waiting close to 20minutes.)
borrowed a usb-a male/male , jumpered it, and plug the emmc in, plug the power in (after installing driver )
and open android tool--- could not detect it.
right now if i plug in the power, i get a dc-in led blinking only.
PSU from pine64.org
led form
stats.power and dc-in are blinking.
  Android9 blinking screen and can't change resolution for home screen AlexS 0 2,031 07-24-2019, 08:06 AM
Last Post: AlexS
  Rock64 With Android TV 7.1 Won't boot using 3.5mm power barrel Eric82 1 2,738 11-19-2018, 03:47 PM
