Rock64 / OMV / Docker
Hi all,
I have a rock64 ordered and I'm waiting for delivery... Looking forward to getting involved with this community.
My current setup is a Mac mini running plex server with a raspberry pi with OMV. I use the RPi for tinkering and a download/file/VPN server.
I'm planning a similar setup when I get the rock64 but I also wanted to see how well it works as a plex / media server. I'm thinking about using docker to run all of the media server related stuff in containers.
As I will be using OMV, I was hoping I could setup docker within OMV on the rock64 and then configure the media server in docker containers.
Possible? good idea? other suggestions?
This may help you: https://forum.pine64.org/showthread.php?tid=5341
(11-03-2017, 05:11 PM)douglasmiranda Wrote: This may help you: https://forum.pine64.org/showthread.php?tid=5341
thanks. I will try this when my rock64 arrives....
To do it the easy way:
apt-get update && apt-get install -y curl apt-transport-https
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | apt-key add -
cat <<EOF >/etc/apt/sources.list.d/docker.list
deb https://download.docker.com/linux/$(lsb_release -si | tr '[:upper:]' '[:lower:]') $(lsb_release -cs) stable
EOF
apt-get update && apt-get install -y docker-ce
That will currently get you 17.09
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 311 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,407 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,759 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,233 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 353 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,939 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,561 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,140 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 772 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 967 10-07-2022, 07:50 PM
Last Post: rookie_267
