ROCK64 uboot HDMI no signal output
When I using the uboot hdmi branch (https://github.com/ayufan-rock64/linux-u...nline-hdmi),
there no signal output.
pinctrl_rk3328_hdmi_config
rk3328_hdmi_config
rk3328_clk_config
rk3328_clk_set_rate: 205
rk3328_vop_set_clk: 384000000
rk3328_hdmi_probe = 0
rk_hdmi_read_edid: 128
rk3328_clk_set_rate: 180
rk3328_lcdc_set_clk: 97750000
rk3328_hdmi_enable
rk3328_hdmi_config
Using phyaddr for writing(addr=0x6 data=0x51)
Using phyaddr for writing(addr=0x15 data=0x2)
Using phyaddr for writing(addr=0x10 data=0x38)
Using phyaddr for writing(addr=0x13 data=0x0)
Using phyaddr for writing(addr=0x17 data=0x6)
Using phyaddr for writing(addr=0x19 data=0x4)
Using phyaddr for writing(addr=0x9 data=0x802b)
Using phyaddr for writing(addr=0xe data=0x28d)
Using phyaddr for writing(addr=0x5 data=0x8000)
rk3328_vop_probe = 0
In:    serial
Out:   vidconsole
Err:   vidconsole
Model: Pine64 Rock64
Net:   rk3328_clk_set_rate: 100
eth0: ethernet@ff540000
Hit any key to stop autoboot:  0
I placed your console log in a code block.
Were you asking a question, or simply stating information ?
if you are using the build you linked to, did you know that it is about 2 months old? that build is among the first for the rock64, i'd suggest that you move to a newer build. you would most likely have fewer issues.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 311 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,407 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,759 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,233 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 353 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,939 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,561 01-17-2023, 02:31 PM
Last Post: Flagtrax
  Latest Manjaro Update fails HDMI Flagtrax 0 584 01-06-2023, 10:47 AM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,140 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 772 11-28-2022, 02:18 PM
Last Post: Macgyver
