Easiest way to flash eMMC
@csphx
I dd straight from an image file.  Haven't tried copying from a mSD card to the eMMC.
(09-27-2017, 07:01 AM)tycoonbob Wrote: @csphx
  OK, thanks for the reply ....
  I will try my working sd card --- <dd> ---> eMMC later today
  and see how it goes .
  If it doesn't fly I should be able to re-format the eMMC
  and go to the proverbial plan b ....
Stanley C. Kitching
Human Being
Phoenix, Arizona
All is well that ends well ....
  Yesterday I successfully cloned my working
  rock64 debian stretch minimal 16 gb sd card
  to a 32 gb eMMC module using the dd command
  running on a debian buster pc ....
  I used two usb3 card readers in a powered
  usb3 hub with the target eMMC attached
  to a  [sd|eMMC ] adapter ....
    # dd if=/dev/sdc of=/dev/sde bs=3M conv=notrunc,noerror status=progress
  The  dd  copy took about 13 minutes
  and the eMMC booted with no problems ....
  This was my first experience with an eMMC module
  and I did find it a bit tedious first attaching it
  to the  [sdc|eMMC]  adapter and then inserting it
  into its designated slot on the rock64 board
  due to its small size ....
Stanley C. Kitching
Human Being
Phoenix, Az
(09-25-2017, 02:56 PM)tycoonbob Wrote: If I only contribute one thing to the rock64 project, I think this should be a good one.
Looking around at instructions and documentation to write an image to the eMMC, I have not come across this yet and it's blowing my mind.
eMMC to microUSB adapter ($1.50):
http://www.hardkernel.com/main/products/...5415955758
I have an oDroid XU4 with an eMMC module, and this is the adapter I've been using to write an image to it (via dd on OSX).  Done the same with my ROCK64, and I think this is something everyone should own if they play with SBC's with eMMC, and I think PINE needs to source these and add them to the store.  In my limited testing, worked like a charm with ayufan's Debian Stretch Minimal image (just straight up used dd to write to the eMMC on my hackintosh, and booted straight to it).
Enjoy.
worked for me!  have you had any luck with other images?
Thanks for posting this. I just received my 32 gig emmc module from pine.
Came on, to find how to load it, found this thread.
I just ordered it, on Amazon, for $6.53,  including shipping.  (ships from ODROID).
Jake
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,071 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,976 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,723 08-19-2021, 06:46 PM
Last Post: bcnaz
  Got an error message when trying to flash the Rock64 OS ilan 0 2,064 06-29-2020, 04:53 PM
Last Post: ilan
  Download IDB fail when trying to flash Android image cherkasoff 0 4,324 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 15,881 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 29,145 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 105,658 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 2,283 02-04-2019, 07:36 AM
Last Post: LMM
  No Boot, Red Green and White flash at 1 sec intervals wesleykonrad 2 4,060 01-28-2019, 11:54 PM
Last Post: wesleykonrad
