Bliss OS for Pinebook
#41
(09-05-2017, 02:12 PM)amilino Wrote: Is it possible to install it (on eMMC) simply like this:
1. Boot Linux from sdcard
2. sudo dd status=progress bs=512 if=/dev/mmcblk1 | gzip > /media/pine64/Elements/Bliss-pine64_pinebook_20170830_01.img.gz
I think all that will do is create a backup of your emmc. What youre looking for is maybe something like
$ sudo gunzip -c /path/to/backup.img.gz | dd of=/dev/sdX
I have not tried it yet, so please do not quote me on it. it might be missing quite a bit to work properly.
That indeed is just to restore a backup image. Currently, the best known method to move to EMMC is found here: https://forum.pine64.org/showthread.php?...3#pid28873
#42
(09-19-2017, 08:23 PM)electrikjesus Wrote: $ sudo gunzip -c /path/to/backup.img.gz | dd of=/dev/sdX
No ! the command you are showing is restoring a backup, not doing one.
#43
Bliss OS (Pinebook) 20170919 (SDCard). Note that, this build is for SD Card boot.
Thanks to Bliss OS team and other community contributors for building this image.
MD5 (GZip file): 6b5bc28d69d575ba5448ad8081a0d356
#44
This is new version? Does anybody know what is new there?
#45
If this is a new version, how to update my current version which is installed on eMMC???
#46
(10-13-2017, 05:51 AM)Wizzard Wrote: This is new version? Does anybody know what is new there?
Here's some info:
https://plus.google.com/+EricParkideaman...NWQz2uxzGD
Bit lower in the post on that page it reads:
Quote:"Bliss Nougat for Pinebook and Pine64 was updated to support Widevine DRM (for Netflix and other video services) as well as a few minor updates, added features and improvements to Freeform window behaviour. So far no negative feedback from this release, so we are counting that as a WIN!"
#47
Here's some info:
Bravo
#48
To bad not to have VPN working, and no update instructions for eMMC instalation. Sad
I would at least appreciate any technical comment like, forget about VPN and forget updates, you have to install everytime new fresh image.
#49
Here's some info:
Thanks for sharing!
#50
There is a newer build - updated the wiki entry.
Smile PrimeOS for Pinebook 1080p teamprimeos 0 2,329 11-08-2021, 08:37 AM
Last Post: teamprimeos
  Lineage + pinebook, havin an issue when porting it Phie 5 8,761 01-18-2021, 09:02 AM
Last Post: mindao
  [26/09/2019] /e/ on pinebook, lineage derivative Phie 16 29,634 03-29-2020, 06:22 AM
Last Post: Surehand53
  Privacy of Android and Chromium on new PineBook Clea 3 6,162 10-15-2019, 09:19 AM
  Android for 1080p Pinebook? Tomash 7 10,770 09-09-2019, 07:30 AM
  Stock Android for 1080P Pinebook pineadmin 1 5,565 11-24-2018, 09:45 AM
Last Post: ramboton
  Android 7.1 (Pinebook) pineadmin 50 75,218 05-30-2018, 03:13 PM
Last Post: Wizzard
  Android 6.0.1 (Pinebook) 20170605 pineadmin 6 12,697 12-30-2017, 06:55 AM
Last Post: milkaca
  Android 7.1 (Pinebook) v0.3.3-r59 pineadmin 3 7,913 05-09-2017, 04:59 AM
Last Post: Luke
  Pre-release android 7.1 for Pinebook Luke 0 5,217 04-22-2017, 10:58 AM
Last Post: Luke
