+PINEBOOK: Newbie Trying to Compile RStudio On Pinebook
Hello Pine64 Community,
I am new to Linux and am trying to get Rstudio on my Pinebook with Q40s installed on the emmc module.  I found instructions from:
 http://herb.h.kobe-u.ac.jp/raspiinfo/rstudio_en.html who documents their experience on a Raspberry Pi 2/3, but I have encountered errors.. Also note that I  did not edit or create a swapfile (I had trouble / didnt feel comfortable, but I also didnt use nano.. I tried just in the GUI with the default program and got a permissions error). Also I didn't mess with the shell... so pretty much everything in the "Requirements" section I passed by  Blush
Aside from the first section I followed their instructions exactly although with my corresponding directories...
But, I get to the line..
cmake .. -DRSTUDIO_TARGET=Desktop -DCMAKE_BUILD_TYPE=Release
When I execute the command and I am experiencing an error.. here is what the output says in my terminal..
root@pine64:/home/adminq/Documents/rstudio/build# cmake .. -DRSTUDIO_TARGET=Desktop -DCMAKE_BUILD_TYPE=Release -- The C compiler identification is GNU 4.9.2 -- The CXX compiler identification is GNU 4.9.2 -- Check for working C compiler: /usr/bin/cc -- Check for working C compiler: /usr/bin/cc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working CXX compiler: /usr/bin/c++ -- Check for working CXX compiler: /usr/bin/c++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- LSB release: debian -- Boost version: 1.63.0 -- Using RStudio-provided Boost 1.63.0 -- Performing Test HAVE_SCANDIR_POSIX -- Performing Test HAVE_SCANDIR_POSIX - Success -- Looking for SA_NOCLDWAIT -- Looking for SA_NOCLDWAIT - found -- Looking for SO_PEERCRED -- Looking for SO_PEERCRED - found -- Looking for inotify_init1 -- Looking for inotify_init1 - found -- Looking for getpeereid -- Looking for getpeereid - not found -- Looking for setresuid -- Looking for setresuid - found -- Found LibR: /usr/lib/R -- Found R: /usr/lib/R -- Performing Test LIBR_MINIMUM_VERSION -- Performing Test LIBR_MINIMUM_VERSION - Success CMake Error at src/cpp/desktop/CMakeLists.txt:84 (find_package):  By not providing "FindQt5WebChannel.cmake" in CMAKE_MODULE_PATH this  project has asked CMake to find a package configuration file provided by  "Qt5WebChannel", but CMake did not find one.  Could not find a package configuration file provided by "Qt5WebChannel"  with any of the following names:    Qt5WebChannelConfig.cmake    qt5webchannel-config.cmake  Add the installation prefix of "Qt5WebChannel" to CMAKE_PREFIX_PATH or set  "Qt5WebChannel_DIR" to a directory containing one of the above files.  If  "Qt5WebChannel" provides a separate development package or SDK, be sure it  has been installed. -- Configuring incomplete, errors occurred! See also "/home/adminq/Documents/rstudio/build/CMakeFiles/CMakeOutput.log". See also "/home/adminq/Documents/rstudio/build/CMakeFiles/CMakeError.log".
So, would anyone be able to assist me with troubleshooting?
Thanks in advance,
MiningBrutus
I have deleted your original duplicate posting .
(08-12-2017, 03:59 PM)MarkHaysHarris777 Wrote: I have deleted your original duplicate posting .
I thought I had deleted it after I re-posted.. I guess not?..  Thank you for deleting
You are welcome;  your delete is called a "soft delete"  --  the moderators come along later and clean things up permanently once they understand you intent.
  +PINEBOOK Fedora 30 on Pinebook sdgathman 0 6,513 08-14-2019, 11:41 AM
Last Post: sdgathman
  Arch, Debian or other for Pinebook? cootcraig 3 11,697 05-01-2019, 09:11 AM
Last Post: cootcraig
  +PINEBOOK Q4OS Pinebook Questions StewB 0 3,733 08-24-2017, 03:53 PM
Last Post: StewB
  How to compile on other systems for Pine utdrmac 3 9,520 03-08-2017, 02:40 PM
Last Post: xalius
  LINUX Distribution for the newbie _mgd 5 11,635 12-10-2016, 11:18 PM
Last Post: speedro86
  Compile kernel 3.10 failed kap1r0t0 8 15,212 05-08-2016, 09:59 PM
Last Post: kap1r0t0
