Is there anyone who got a compatible bluetooth dongle
I'm concerned about how to connect the controller wirelessly.
I haven't got my rock64, just curious.
(08-11-2017, 10:40 AM)fbms Wrote: I'm concerned about how to connect the controller wirelessly.
controller ? Keyboard ? If you are asking about the keyboard then there shouldn't be any issues. As for controllers, I tried 8bit do with a generic BT dongle and had no problems.
I have a Logitech K 400 plus ... has worked flawlessly,on all the rock 64 images I've tried.
[I am having problems with USB ports not working, after the login screen, in some builds, but am still working on narrowing it down .. I plan to post on it, once I can define exactly when, on what OS ISO it is happening. I can say ..it is not a hardware problem .. I can always get to the login screen, and type, use trackpad no problem.. it is after that, that sometimes, the USB ports quit working .. as I said, when I can quantify the problem, will post more].
Jake
BT chipset that worked for me out of the box: CSR8510
(08-11-2017, 11:55 AM)Luke Wrote: BT chipset that worked for me out of the box: CSR8510
Thank you, Luke. Your information is very useful.
I bought ROCK64 USB BLUETOOTH BLE 4.0 (CSR8510 A10) from the store. I am not having any luck getting it work. I am plugging it into a USB2.0 slot with android 7.1 on 64GB eMMC on the Rock64 4GB. Not even sure how to "install" it as PnP doesn't seem to be supported. Any help would be appreciated. Thanks!
-Jon
(09-27-2017, 01:57 PM)tarlo766 Wrote: I bought ROCK64 USB BLUETOOTH BLE 4.0 (CSR8510 A10) from the store. I am not having any luck getting it work. I am plugging it into a USB2.0 slot with android 7.1 on 64GB eMMC on the Rock64 4GB. Not even sure how to "install" it as PnP doesn't seem to be supported. Any help would be appreciated. Thanks!
-Jon
Linux supports 2 out of the 3 BT dongles I have, but I couldn't get any of them to work in Android. I may be wrong, but its probably not yet supported in the kernel on android ...
-Jon
I have the same issue Rock 64 on Android 7.1.2 and the BT dongle CSR8510 isn't working. I tried to switch the BT option in the setting on android with no success.
Anybody has any idea how to make this work ?
Seb
  Compatible WiFi modules for Rock64 j3eeenet 8 13,351 08-08-2018, 02:06 AM
Last Post: AnythingIsFine
  USB WiFi/BT dongle gas14 9 10,448 10-24-2017, 01:31 AM
Last Post: gas14
