safe fanout for Digital outputs?
How many outputs can a GPIO drive?
I have several ADC's I want to send a clock signal too all at the same time, is there a general rule of tumb of how many devices a pine output can drive at once?
Thanks!
I should mention I'm clocking a dozen or so ADC0832's, they are all reading hall effect sensors
(07-25-2017, 12:45 PM)ealbers Wrote: How many outputs can a GPIO drive?
Thanks!
Always refer to the datasheet.
... having said that, typical fanout is about 10.  Depending on TTL or CMOS technology.  TTL is a current sinking logic so fanout is more constricted. Each device by logic type is somewhat different.
If you are concerned about it, then use an inverter | driver or just an hex driver buffer between your devices and the clock output signal.  A half dozen or so should not be a problem regardless.
Read the datasheet.
  Digital Signage redpine 2 4,427 05-31-2017, 05:58 AM
Last Post: redpine
Music Tuning and overclocking for Mixxx - digital dj interface Pander 0 1,688 12-04-2016, 07:31 AM
Last Post: Pander
