Tor relay
Hi guys,
As you may know, I have recently received a PINE64 1GB board where I run ubuntu 16.04 xenial and one of the reason for which I wanted to own a PINE64 was to run a Tor relay.
If you are interested on running a Tor relay too, you can find instructions on my last blog post:
http://blog.antani.co/pine64-tor-relay/
Please let me know if anything is missing or could be improved.
Cool idea and thank you for writing up both the ubuntu install and the tor setup.
I'm currently running a Tor relay on a Raspberry Pi 2, and I ordered the Pine64 to see if it performs better. If it does, I'll be ordering more to run as many relays as I can. However, I'm planning on using Debian as its what I'm use to.
(03-13-2016, 01:37 PM)Ohheyalan Wrote: I'm currently running a Tor relay on a Raspberry Pi 2, and I ordered the Pine64 to see if it performs better. If it does, I'll be ordering more to run as many relays as I can. However, I'm planning on using Debian as its what I'm use to.
You can keep an eye on my node statistics here: https://atlas.torproject.org/#details/CA...EF7F75EC6E
  P64 as relay? etsoft 1 4,900 01-22-2017, 09:20 PM
Last Post: MarkHaysHarris777
