help with LCD touch configuration using tslib
  I bought a Pine64+ board and screen, with a view to using it as a Squeezebox Touch replacement through a USB dac. The board ticks a lot of the hardware boxes for a Squeezebox Touch, with dedicated ethernet and USB ports/busses.
Armbian runs out of the box and supports the touchscreen - at least with legacy 3.10.104 kernel. With mainline kernel (4.10 at time of writing) touchscreen support is available through the generic "goodix" module, but this requires some extra configuration.  I have not yet evaluated the mainline kernel's readiness to run the system that I have in mind.
Using Armbian legacy  (3.10.104), I have installed the packaged Squeezelite from the Armbian repository and Jivelite compiles and runs without errors using
https://github.com/sindrom91/LuaJIT/tree/ARM64
Athough touch events work perfectly in Xfce, they are "all over the place" in Jivelite, so I'm trying to create a tslib/SDL calibration.
Just now I'm struggling with
"tslib: Selected device is not a touchscreen (must support ABS and KEY event types)"
Googling throws up one or two bits of advice, such as:
From http://http://www.cubieforums.com/index....v.html#new:
Quote:Check if input-raw.c has:
    if ((ioctl(ts->fd, EVIOCGBIT(EV_ABS, sizeof(absbit)), absbit)) < 0 ||
       !(absbit[BIT_WORD(ABS_X)] & BIT_MASK(ABS_X)) ||
       !(absbit[BIT_WORD(ABS_Y)] & BIT_MASK(ABS_Y))) {
      /*fprintf(stderr, "tslib: Selected device is not a touchscreen (must support ABS_X and ABS_Y events)\n");
      return -1;*/
if not, edit the file and comment the lines."
and
from http://stackoverflow.com/questions/11937...-calibrate:
Quote:Try to add
input_dev = input_allocate_device();
set_bit(EV_ABS, input_dev->evbit);
set_bit(EV_KEY, input_dev->evbit);
So that the tslib sees the device as supporting both EV_ABS and EV_KEY events (even if it does not actually send both of those).
(I'm assuming this should also be in input-raw.c)
If I look at my own input-raw.c, I see:
static int check_fd(struct tslib_input *i)
        struct tsdev *ts = i->module.dev;
        int version;
        long evbit[BITS_TO_LONGS(EV_CNT)];
        long absbit[BITS_TO_LONGS(ABS_CNT)];
        long keybit[BITS_TO_LONGS(KEY_CNT)];
        long synbit[BITS_TO_LONGS(SYN_CNT)];
        if (ioctl(ts->fd, EVIOCGVERSION, &version) < 0) {
                fprintf(stderr, "tslib: Selected device is not a Linux input event device\n");
                return -1;
        /* support version EV_VERSION 0x010000 and 0x010001
         * this check causes more troubles than it solves here */
        if (version < EV_VERSION)
                fprintf(stderr, "tslib: Warning: Selected device uses a different version of the event protocol than tslib was compiled for\n");
        if ( (ioctl(ts->fd, EVIOCGBIT(0, sizeof(evbit)), evbit) < 0) ||
                !(evbit[BIT_WORD(EV_ABS)] & BIT_MASK(EV_ABS)) ||
                !(evbit[BIT_WORD(EV_KEY)] & BIT_MASK(EV_KEY)) ) {
                fprintf(stderr, "tslib: Selected device is not a touchscreen (must support ABS and KEY event types)\n");
                return -1;
                if (!(absbit[BIT_WORD(ABS_MT_POSITION_X)] & BIT_MASK(ABS_MT_POSITION_X)) ||
                    !(absbit[BIT_WORD(ABS_MT_POSITION_Y)] & BIT_MASK(ABS_MT_POSITION_Y))) {
                        fprintf(stderr, "tslib: Selected device is not a touchscreen (must support ABS_X/Y or ABS_MT_POSITION_X/Y events)\n");
                        return -1;
        /* Since some touchscreens (eg. infrared) physically can't measure pressure,
         * the input system doesn't report it on those. Tslib relies on pressure, thus
         * we set it to constant 255. It's still controlled by BTN_TOUCH/BTN_LEFT -
         * when not touched, the pressure is forced to 0. */
        if (!(absbit[BIT_WORD(ABS_PRESSURE)] & BIT_MASK(ABS_PRESSURE)))
                i->no_pressure = 1;
        if ((ioctl(ts->fd, EVIOCGBIT(EV_KEY, sizeof(keybit)), keybit) < 0) ||
                !(keybit[BIT_WORD(BTN_TOUCH)] & BIT_MASK(BTN_TOUCH) ||
                  keybit[BIT_WORD(BTN_LEFT)] & BIT_MASK(BTN_LEFT))) {
                fprintf(stderr, "tslib: Selected device is not a touchscreen (must support BTN_TOUCH or BTN_LEFT events)\n");
                return -1;
        /* Remember whether we have a multitouch device. We need to know for ABS_X,
         * ABS_Y and ABS_PRESSURE data. */
        if ((absbit[BIT_WORD(ABS_MT_POSITION_X)] & BIT_MASK(ABS_MT_POSITION_X)) &&
                i->mt = 1;
        /* remember if we have a device that doesn't support pressure. We have to
         * set pressure ourselves in this case. */
        if (i->mt && !(absbit[BIT_WORD(ABS_MT_PRESSURE)] & BIT_MASK(ABS_MT_PRESSURE)))
                i->no_pressure = 1;
        if (evbit[BIT_WORD(EV_SYN)] & BIT_MASK(EV_SYN))
                i->using_syn = 1;
        if ((ioctl(ts->fd, EVIOCGBIT(EV_SYN, sizeof(synbit)), synbit)) == -1)
                fprintf(stderr, "tslib: ioctl error\n");
        /* remember whether we have a multitouch type A device */
        if (i->mt && synbit[BIT_WORD(SYN_MT_REPORT)] & BIT_MASK(SYN_MT_REPORT) &&
            !(absbit[BIT_WORD(ABS_MT_SLOT)] & BIT_MASK(ABS_MT_SLOT)))
                i->type_a = 1;
        if (i->grab_events == GRAB_EVENTS_WANTED) {
                if (ioctl(ts->fd, EVIOCGRAB, (void *)1)) {
                        fprintf(stderr, "tslib: Unable to grab selected input device\n");
                        return -1;
                i->grab_events = GRAB_EVENTS_ACTIVE;
        return ts->fd;
and I can't see why the test is failing as
  • TS_INFO_FILE=/sys/devices/virtual/input/input6/uevent:
          I: Bus=0018 Vendor=dead Product=beef Version=28bb
            N: Name="gt9xxf_ts"
            P: Phys=input/goodix-ts
            S: Sysfs=/devices/virtual/input/input6
            U: Uniq=
            H: Handlers=event5 autohotplug cpufreq_interactive
            B: PROP=2
            B: EV=b
            B: KEY=400 0 0 0 0 0
            B: ABS=265000000000000
  • # evtest /dev/input/event5
            Input driver version is 1.0.1
            Input device ID: bus 0x18 vendor 0xdead product 0xbeef version 0x28bb
            Input device name: "gt9xxf_ts"
            Supported events:
            Event type 0 (EV_SYN)
            Event type 1 (EV_KEY)
                Event code 330 (BTN_TOUCH)
            Event type 3 (EV_ABS)
                Event code 48 (ABS_MT_TOUCH_MAJOR)
                    Value      0
                    Min        0
                    Max      255
                Event code 50 (ABS_MT_WIDTH_MAJOR)
                    Value      0
                    Min        0
                    Max      255
                Event code 53 (ABS_MT_POSITION_X)
                    Value      0
                    Min        0
                    Max     1024
                Event code 54 (ABS_MT_POSITION_Y)
                    Value      0
                    Min        0
                    Max      600
                Event code 57 (ABS_MT_TRACKING_ID)
                    Value      0
                    Min        0
                    Max      255
            Properties:
                Property type 1 (INPUT_PROP_DIRECT)
Can anyone point me in the right direction to getting the device calibrated?
I figure that if I (with help) can get this working, it might be an excellent and cheap squeezebox touch alternative.
BR.
--Marius-
  Armbian touch screen isuues tjnoma99 5 13,208 02-17-2017, 04:12 PM
Last Post: Luke
