Click on desktop Icon blanks sceen
Hello, thanks to all who contribute to the Pine64 projects
I have a Pine 64 2GB
Connected to  a display through a HDMI to VGA adapter
Android 6.0 Image (HDMI Video Output) Release 20170112 ver 2.0.1
Remix OS 2.0 Image Release 20170105
The Home screen displays perfectly, any time I click on an ICON the screen goes blank, forever.
The OS appears to be running.
That is as far as I have gotten in my first few days.
Any ideas would be appreciated.
R
(01-22-2017, 07:16 PM)CreateControl Wrote: Hello,
hi, meet with us on the irc channel below, and we will try some debugging with you.
What you are seeing is of course not normal;  more likely than not the display is the issue.
... place a serial usb to TTL bridge cable ( debug cable ) on the serial console, and watch the bootup, also watch the serial console when the screen goes blank... is the OS really running ?
see you on the irc
see you on the irc
Hi and thanks very much.
I hadn't clued up to the using the debug port as I had on other devices.
I cannot follow through at this moment and i will follow through within a day or two.
Again, thanks
see you on the irc
Mark Harris, I have my cable built and connected, can you advise me on the comms 115200,8,1,n.n
Thank You
rk Harris
Please advise me on the comms 15200,8,1,n,n
Does that seem correct?
I closed your duplicate thread.
First , use this link to find the Tx , Rx , and ground pins for the serial console on the EXP bus.
You may use 115200,8,n,1
Use this link to find a good cable.
The serial console just works.  Make sure that your wires are crossed properly:  Tx --> Rx   ;   Rx --> Tx
Also, make sure the ground wire is connected. You may use any serial terminal emulator on another computer to monitor the serial console on your pine board.  ( minicom, screen , and others )  I prefer to use gnu+linux ( Mint ) but you may also use your mac, or even Windows.
Again, it would be easier to help you live on the irc.  Stop by and we can chat.
Edit: irc is not the irc section of the forum... irc stands for Internet Relay Chat. You may use a free client like weechat ( or others ) to access the irc @ the address listed below .
Edit: If you're using the cable I recommended above the green wire (Tx) goes to EXP pin(8 Rx), the white wire (Rx) goes to EXP pin(7 Tx) , and the ground wire (black) goes to EXP pin(9 Gnd).
  Setting up QT for compiling on my desktop vincer 0 3,693 09-19-2020, 03:31 PM
Last Post: vincer
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,825 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 39,639 04-05-2017, 01:45 PM
Last Post: speedro86
Exclamation recurring blank screen on A64+ with ubuntu image & any desktop gui faddah 5 11,754 06-15-2016, 10:55 AM
Last Post: jl_678
