Onboard computer and gps for motorhome
I'm thinking that with so many navigation apps on android, it might be possible to install a pine with touch display in the motorhome I'm buying as a reasonably priced satnav with the bonus that it could use wifi and bluetooth when available to integrate with entertainment systems and be also used as an internet link for email etc.
Two questions, one, am I expecting too much of the system? Two, are there any gps modules available?
Just thinking out loud.
you can use raspberry pi GPS, it's same pin connector, or you can use, UART connector for you GPS, or for the futur maybe with POT: Multi I2C Bus if planned
Lightbulb Server for filesharing to computer? LordCanti 3 8,072 03-06-2016, 04:17 PM
Last Post: NWUK
  pine A64 as midi computer urison 1 5,752 02-16-2016, 08:38 AM
Last Post: taros
