micro SD speed
I was reading that the new Odroid C2 has a micro SD clock of 83MHz and a bus speed of SDR50 (up to 50 MB/s), and that the Raspberry Pi has a micro SD clock of 50MHz and a bus speed of SDR25 (up to 25MB/s). What is the micro SD clock and bus speed of the Pine 64?
(02-08-2016, 05:30 PM)stephen fleming Wrote: I was reading that the new Odroid C2 has a micro SD clock of 83MHz and a bus speed of SDR50 (up to 50 MB/s), and that the Raspberry Pi has a micro SD clock of 50MHz and a bus speed of SDR25 (up to 25MB/s). What is the micro SD clock and bus speed of the Pine 64?
I thinks the SDR25 should be a correct one, even to Odroid C2. The Pine A64's SoC can perform SDR50 but I don't think micro SD which operate at 3.3volt can perform on such speed. I will be glad to prove wrong.
According to a test they did, the Odroid C2 did 36.7 MB/s for UHS-1 read and 15.5 MB/s for UHS-1 write.
Not sure if this pertains to the conversation, but I was able to transfer a Dreamcast ISO from a Flash drive to the Pine through a USB Hub at 19-29MB/s.
(02-09-2016, 12:12 PM)KryPtAlIvIaN Wrote: Not sure if this pertains to the conversation, but I was able to transfer a Dreamcast ISO from a Flash drive to the Pine through a USB Hub at 19-29MB/s.
Unfortunately no, the SD interface is not the same as the USB. I do not have my Pine 64 yet, so I can not do any testing myself. However, if you are running Linux here are the commands the people a Hard Kernel used to do the test on the Odroid C2:
   Write command
   dd if=/dev/zero of=test oflag=direct bs=8M count=64
   Read command
   dd if=test of=/dev/null iflag=direct bs=8M
Depending on how fast you micro SD card is, that can also effect the results.
   Write command
   Read command
I don't talk anymore , but you topic is this  price $40 Odroid C2 2G to compare $29 pine64 2G i saw is not fair.
if Odroid C2 the price is $29 , i think is fair to compare .
and pine64 have 1G , 2G choose , but Odroid C2 have not , and for me is basic user only 1G $19 enough
Any updates?
I'm looking at different micro SD's and would like to know which one to buy (C10 / U1 / U3).
(03-12-2016, 08:31 AM)Danton Wrote: Any updates?
Class 10. UHS performance brings no benefits for the Pine (this was discussed in another thread, I'll try and find it).
Yup, it was here.
Thanks for your answer!
jjwerner@localhost:~$ dd if=/dev/zero of=test oflag=direct bs=8M count=64
dd if=/dev/zero of=test oflag=direct bs=8M count=6464+0 records in
536870912 bytes (537 MB, 512 MiB) copied, 24.029 s, 22.3 MB/s
536870912 bytes (537 MB, 512 MiB) copied, 24.0569 s, 22.3 MB/s
Sandisk Extreme 32GB U1 micro SD card
  High speed I/O richw42 3 10,387 01-15-2017, 04:08 PM
Last Post: richw42
