10-21-2016, 10:01 AM
I didn't know which group to post this in. I figured since you plugin a SD Card this would be the closest.
I bought a 64GB SD Card directly from pine. I was able to flash the 64GB android image for touch screen onto the card.
I then bought a name brand Sandisk SD Card from Newegg. I was not able to flash the 64GB android hdmi image on that card because it said it was too small.
I then found out that Newegg sells things from outside vendors, so I thought maybe I was a victim of a scam card. It says it has 58GB of space on it.
I then went to Costco and purchased a 32GB SD card from Sandisk thinking that Costco items should be legit, right?
I downloaded the 32GB android image for hdmi and when I tried to flash that image was told again that there wasn't enough room on the card.
I am using a Mac with El Capitan.
I am using the Etcher app recommended on the Pine64 wiki. That app worked fine on the Pine64 card I bought direct. It just doesn't work on any other SD Card or image that I have tried.
Can someone tell me what is going on?
