LCD Monitor resolution problem
Hi all. The Pine64 Debian Xfce image does not detect my LCD monitor resolution correctly. For some reason it is using 1280 x 760 or such. The correct resolution is 1920 x 1080. The Pine64 Ubuntu mate image does not suffer from this problem - It works at the correct resolution. My OpenSuse Desktop also uses this monitor at 1920 x 1080.  Any ideas on how to address this?
The debian image has the resolution set to 720p by default. See this thread for steps to change it:
http://forum.pine64.org/showthread.php?tid=980
(09-20-2016, 03:22 PM)psychedup Wrote: The debian image has the resolution set to 720p by default. See this thread for steps to change it:
Ok thanks - matter is resolved
  OMV base on Debian jessie Root Problem ayamy 3 5,614 09-03-2017, 09:21 PM
  Synergy dependency problem S265 3 5,401 10-27-2016, 12:44 PM
Last Post: TidBits
  Debian Base (3.10.102 BSP 2) won't boot without monitor Scion 7 12,269 09-16-2016, 03:58 PM
Last Post: Scion
  How can I change the screen resolution? miffy_bf 5 12,055 06-28-2016, 03:54 PM
Last Post: coolnine98
