Rooted Android 5.1.1 - Phone, Dialler & SMS
Question
Hi
I've installed the rooted version of Lollipop and it's very impressive!
Having plugged a 3G USB dongle for phone / text capability, I've noticed that there are no stock apps related to eitrher the phone or SMS. I installed an SMS app (ZERO SMS), and can successfully send a text, but cannot receive one.
With regards to the phone capability, as there doesn't appear to be a dialler, I obviously can't make calls. When I call the number on the SIM within the dongle, it rings, so it is definitely online (also demonstrated by the signal status), but there is no further screen interaction.
I've found a link to the Google Dialler (https://play.google.com/store/apps/detai...aler&hl=en), but opening it up within the Play Store informs me that my device is incompatible, therefore I cannot download it. At a push, I could probably spoof the model to enable the download & installation, but there is no guarantee it would work.
The /System/App/ folder doesn't appear to have anything relevant. I've found many APKs which purport to be from stock ROMs, but I'm dubious about compatability & source.
Has anyone managed to successfully enable their Pine Android to both make & receive calls & texts?
You would have to change the device properties that it submits to the play store to include calling etc. You should be able to flash Gapps to install the required libraries for SMS, as for receiving you'd probably need to write your own layer to integrate it with the Android OS.
Backer #6878
shipment status: arrived
google phone is on apkmirror
http://www.apkmirror.com/apk/google-inc/...#uploadAPK
as far as sms you could try hangouts.
http://www.apkmirror.com/apk/google-inc/...-download/
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,626 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,794 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,877 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,005 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,080 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,354 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,284 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,558 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,462 02-10-2019, 07:44 PM
Last Post: mmmarcus
