Basic Pine64 Server Set-Up Guide
https://www.reddit.com/r/pine64/comments...ource=link
If you have any suggestions or questions I will try to resond. I will probably try to get another part of the guide up soon.
This should totally work with any of the pine64's  - my own setup - much more complicated and layered - has a 1.5 gigs of free ram.
Hopefully by next Monday I will have a guide setup for how to setup containers.
I was trying to post on here but formatting turned into a nightmare - probably my own fault.
hi, write it up and try again; I will make a 'sticky' note from it.
My suggestions would be the same I make to those trying to build web pages; keep it simple, left justified, use simple headings, and italics, and keep the fonts normal.
I will close and remove your previous post.
  Programming languages support under PINE64 baryluk 6 19,731 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,114 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 36,741 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,307 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 9,567 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 53,529 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,751 08-21-2018, 10:54 PM
Last Post: r.tanaka
  OpenWRT installation guide Sander 0 5,017 07-09-2018, 09:42 AM
Last Post: Sander
  DKMS on kernel 3.10.107-pine64 obrienmd 5 13,699 06-21-2018, 05:45 PM
Last Post: evilbunny
  need help, looking to setup NAS server over OpenWRT subbu 0 3,933 05-26-2018, 07:48 AM
Last Post: subbu
