(08-08-2016, 04:30 AM)martinzheng Wrote:Sorry on the broken ffu file, I have already reload the full 1.1GB ffu file to wiki server and please download again. Here is the link: http://files.pine64.org/os/win10-iot/Win...Pine64.ffu(08-07-2016, 10:30 PM)dkryder Wrote: this is from DISM.log after a failed flash. the flash process had proceeded to the 30% mark successfully before issueing the error. the dashboard reported that the SDcard was not formatted, but of course it had been. most recently by windows after the first time this message appeared. it's a good card. any ideas?
2016-08-07 21:16:58, Error DISM FFU Provider: PID=7652 While reading image data, a hash check failed. - CFfuManager::FfuLog
2016-08-07 21:16:58, Error DISM FFU Provider: PID=7652 While applying the image to disk, a read failed to return all of the blocks specified in the current data descriptor. hr = 0x2dbe260b. - CFfuManager::FfuLog
2016-08-07 21:16:58, Error DISM FFU Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\ffuprovider\dll\ffumanager.cpp:240 - CFfuManager::Apply(hr:0x8007000e)
2016-08-07 21:16:58, Error DISM FFU Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\ffuprovider\dll\ffumanager.cpp:163 - CFfuManager::ApplyImage(hr:0x8007000e)
2016-08-07 21:16:58, Error DISM DISM Imaging Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\imagingprovider\dll\genericimagingmanager.cpp:2581 - CGenericImagingManager::InternalCmdFFUApply(hr:0x8007000e)
2016-08-07 21:16:58, Error DISM DISM Imaging Provider: PID=7652 TID=9676 onecore\base\ntsetup\opktools\dism\providers\imagingprovider\dll\genericimagingmanager.cpp:535 - CGenericImagingManager::ExecuteCmdLine(hr:0x8007000e)
2016-08-07 21:16:58, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2016-08-07 21:16:58, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
This is because the ffu file that you are using is broken. I think Tim would update a new image.
KERNEL_SECURITY_CHECK_FAILURE at boot + no network/mouse/kb
08-08-2016, 10:12 AM
(08-08-2016, 07:34 AM)dkryder Wrote: the file on the pine64 site is 300MB, the file on onedrive is no longer there. Sorry on the broken ffu file, I have already reload the full 1.1GB ffu file to wiki server and please download again. Here is the link: http://files.pine64.org/os/win10-iot/Win...Pine64.ffu
08-08-2016, 10:28 AM
Using an USB hub and USB2Ethernet adapter I had lying around I indeed seem to be able to have keyboard, mouse and networking!
08-08-2016, 12:30 PM
08-08-2016, 07:02 PM
08-08-2016, 11:50 PM
(08-08-2016, 07:02 PM)Leeway213 Wrote:(08-08-2016, 07:34 AM)dkryder Wrote: the file on the pine64 site is 300MB, the file on onedrive is no longer there. ok. yes, i was able to download the ffu. thank you, tllim, for putting it up. i was able to boot , however had problems with provisioning and as a result had everthing but internet working. i am using a usb hub with wireless keyboard/trackpad and hub has ethernet jack but i think microsoft keeps net access off until the device is properly provisioned. i have no ip address at this point. the hub works fine with debian so i know the hardware is ok. not sure what i can do. i'd rather not flash again.
08-09-2016, 12:23 AM
(08-08-2016, 11:50 PM)dkryder Wrote:A hub with Ethernet? Do you know which Ethernet chip it uses? currently, IoT core can support ax88772.(08-08-2016, 07:02 PM)Leeway213 Wrote:(08-08-2016, 07:34 AM)dkryder Wrote: the file on the pine64 site is 300MB, the file on onedrive is no longer there. (08-09-2016, 12:23 AM)martinzheng Wrote:https://www.amazon.com/gp/product/B0178H...UTF8&psc=1(08-08-2016, 11:50 PM)dkryder Wrote:A hub with Ethernet? Do you know which Ethernet chip it uses? currently, IoT core can support ax88772.(08-08-2016, 07:02 PM)Leeway213 Wrote:(08-08-2016, 07:34 AM)dkryder Wrote: the file on the pine64 site is 300MB, the file on onedrive is no longer there. http://www.tecknet.co.uk/hu043.html i'll try to locate info you want. this works great out of box with debian build. i'm able to bind 2 ethernet feeds into one very strong feed. i think it is realtek RTL8153 http://www.realtek.com.tw/products/produ...ProdID=326
08-09-2016, 04:43 AM
Is it possible for the IoT Core to support the rtl8201cp and rtl8211e chips that are present in Pine A64+ so that it is able to natively support ethernet without the need for a converter.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
08-09-2016, 08:14 PM
I cant connect to the network. | MasahiroSakashita | 3 | 6,194 |
01-25-2017, 11:54 AM Last Post: MarkHaysHarris777 |
