www.pine64eu.com is blocking VPNs
Hi
I use a VPN and I am blocked by EU Shop
How-To order a PineBook Pro?
curl https://www.pine64eu.com
curl: (28) Failed to connect to www.pine64eu.com port 443 after 75004 ms: Couldn't connect to server
~ took 1m15s
(04-06-2024, 11:08 PM)Clea Wrote: Hi
~ took 1m15s
i'm sort of defening pine store for this.
no store would like fraudsters. pine eu store is accepting credit cards, so it is natural take some precautions against some criminals.
vpn might be good privacy, but buyers are giving address and some personal details to a store anyway, so how much vpn benefits anyway.
disclaimer, i am not part of pine64 org or do not represent pine64 org.
(04-06-2024, 11:08 PM)Clea Wrote: I use a VPN and I am blocked by EU Shop
Any of:
  • turn off your VPN and connect to www.pine64eu.com, OR
  • reconfigure your default routes so that www.pine64eu.com (and possibly other domains it uses internally, e.g., for credit card processing) are routed through your physical interface instead of the VPN (though it might lead to, e.g., the payment failing if your whitelist is too short), OR
  • try ordering from somewhere else, maybe pine64.com from Hong Kong.
  Will there be more paying options for Pine64EU? bosi564 4 1,909 03-19-2023, 03:39 PM
Last Post: Amours
  I think AT&T is blocking pine64.org binarycat 1 2,588 01-29-2021, 08:25 PM
