32bit linux until Mali is ok?
Hi everyone,
I want to start using my 2gb pine64 as a home server + 4k HTPC.
From what I can tell, it seems like there has been some great progress with the Mali driver but it's not quite ready yet. So I wonder if there's a way to use 32bit linux (not Android though) with supported Mali drivers? Has anyone tried that?
Once all issues with Mali are resolved I will install a 64bit OS.
Thanks!
Hi
For starters, keep your expectations down - its unlikely that a $30 board will replace a $400 4K HTPC.
Secondly, we already have mali working - but there are bugs and issues to be sorted out.
Lastly, there's no 32bit OS for the Pine64.
If all you want is a HTPC why not run kodi on android ?
This issue is the memory constraint for 32bits. The 64bit image is required for the 2Gb board. Sit tight,... because things are being sorted as we speak... its an exciting time !
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,635 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 97,045 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,457 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,860 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 73,726 01-28-2019, 11:05 PM
Last Post: necrose99
  Real-time linux kernel Artyom 45 125,685 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 10,474 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 9,256 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 6,785 08-03-2017, 10:05 PM
Last Post: pfeerick
  Can I run Alpine Linux on Pine64? douglasmiranda 3 12,479 08-01-2017, 07:20 AM
Last Post: cztian
