Updating the "extra" repository breaks the Danctnix OS
So, I'm new to Arch. Might be more of an Arch question, but here goes:
I recently broke my OS by updating a bunch of stuff from the "extra" repos. When I ran the following to update:
sudo pacman -Syu
It asked me if I wanted to basically reinstall a bunch of already installed packages via the "extra" repository. I was tired of seeing that prompt, so I finally just said yes to everything. After that, the OS wouldn't boot. I did this twice actually. Same thing happened.
I successfully reinstalled the OS, I just don't want to make the same mistake a third time.
How do I either avoid breaking the OS with extra or make sure that the prompt isn't annoying me all the time?
Thanks,
Evergreen
  Arch Linux (danctnix) virtual keyboard layout change cudo 0 710 09-27-2023, 12:19 PM
Last Post: cudo
  Udemy not working on pinetab2 (danctnix) jbreese 3 1,152 06-13-2023, 11:34 AM
Last Post: jbreese
