Recovery without Tow Boot
I had similar problem and was about to throw my PPP against the brick wall behind me thinking that would be the best fix . But then I found the  Installer Version of Mobian and gave this a run .Bingo !
https://images.mobian.org/pinephonepro/
Using this I managed to get Mobian installed when nothing else would ( similar issues to yours ).
I am not sure but postmarket OS may have an installer version as well so you could possible go looking for that if Mobian is not to your liking .
Anyway I am fooling around with Mobian working ( sort of) on the Pinephone Pro that I was about to bin . Hope this works for you .
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 46,095 02-13-2024, 02:54 PM
Last Post: fxc
  What to do if your PinePhone Pro does not boot fxc 19 19,852 09-10-2023, 03:19 AM
Last Post: fxc
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 1,863 02-18-2023, 06:14 PM
Last Post: fxc
  tow-boot installation problem techariah 2 1,556 02-16-2023, 02:50 PM
Last Post: techariah
  create tow boot .img fox95 6 3,146 10-21-2022, 11:40 AM
Last Post: fox95
Question Recovery/Live image? Greendrake 0 862 07-18-2022, 02:09 AM
Last Post: Greendrake
  No display on early boot after Manjaro update robocone 0 868 07-07-2022, 05:47 AM
Last Post: robocone
  Latest Manjaro-Phosh and Arch-Phosh won't boot grinzie 6 3,938 07-01-2022, 02:01 PM
Last Post: Chief
  Manjaro update, no boot, just noise. wilmarcdw 2 1,715 05-09-2022, 07:24 AM
Last Post: wilmarcdw
  Can't boot from a microSD card WhyNotHugo 5 3,216 04-10-2022, 09:15 AM
Last Post: WhyNotHugo
