Uh, where is the source for that claim? The PinePhone design differs significantly from the Samsung Galaxy J7. The batteries are compatible, but, e.g., the display is larger on the PinePhone, so screen protectors for the J7 will likely not fit (get one for the iPhone Xs Max / 11 Pro Max instead). The SIM slot may or may not be the same as on the J7, so do you have any source saying it is the same?
Not to be rude even if it is worded this way, the part of me owning a j3 that had the same sim slot placement and me selling the j7 with the same sim placement should also say otherwise. you can also go on youtube or look in a search for the samsung galaxy j7 and j3 also.
01-03-2024, 04:20 PM
(This post was last modified: 01-03-2024, 04:22 PM by KC9UDX.)
Using parts that Samsung used, in a similar way to the way Samsung used them, to build a new phone called PinePhone is hardly the same as the PinePhone having been designed by Samsung.
I have handheld radios that look identical on the outside and have similar parts with similar placement, but the parts are not interchangeable, and the gubbins are not even similar.
:wq
[ SRA accepts you ]
