Fresh install and i can't get my device to work
So i have a fairly old Dev pine time and i wanted to start it fresh.  So these are the steps i took
nrfjprog -f NRF52 --recover
//using this hex - https://github.com/NordicSemiconductor/n...device.hex
nrfjprog -f NRF52 --program aboveHexFile.hex --verify --sectorerase
//https://github.com/InfiniTimeOrg/InfiniTime/releases/download/1.13.0/pinetime-mcuboot-app-dfu-1.13.0.zip
nrfjprog -f NRF52 --program latestPinetime.hex --verify --sectorerase
nrfjprog -f NRF52 --reset
I followed these steps here.
https://wiki.pine64.org/wiki/Reprogramming_the_PineTime
After i did these steps nothing is working.
I'm guessing the softdevice version hasent changed because i updated my other watch from just bluetooth and it worked perfectly.  Any thoughts on how to solve this problem.
So my goal is to put espruino on it.
So i found this repo https://github.com/fanoush/ds-d6/tree/ma...ino/DFU/P8
So i flashed this hex file and it seemed to work.
https://github.com/fanoush/ds-d6/blob/ma...2_SD30.hex
nrfjprog -f NRF52 --program espruino_2v08.189_p8_SDK12_SD30.hex --verify
From here i can connect to the Espruino IDE over bluetooth!
Going to see now if i can get a newer version of the software
Almost have a new build.
Quick reminders. When you flash it the LCD is not current enabled, so it hard to tell if its on. So you need to click the button if you can't connect to the device. That will power the device on.
Copy the P8-SDK12.py, to the boards section of expruino then build it.
//setups up the code for the specific chip
source scripts/provision.sh NRF52832DK
make -j BOARDNAME=P8 BOARD=P8-SDK12 RELEASE=1 NRF_SDK12=1 VERBOSE=1 USE_BOOTLOADER=1
So you'll make a hex image and it will be in the bin folder.
nrfjprog -f NRF52 --program espruino_2v19.86_p8_SDK12_SD30.hex --verify
  Error: Device rejected by app jojuma 1 929 05-21-2023, 07:03 PM
  ST7789V LCD problem (RAMWR does not work for me) breeze 1 1,395 04-06-2022, 12:57 AM
Last Post: breeze
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 1,522 03-28-2022, 08:22 PM
Last Post: danimations
  TicWatch Pro 2020 with Ubuntu Touch as a PineTime Pine64 device? Peter Gamma 8 10,796 03-25-2021, 02:27 PM
Last Post: antoinem
