Abiword as a office mobile word processor for the Pinephone?
(10-23-2023, 10:15 AM)Peter Gamma Wrote: Thanks for sharing this walter.
Do you also use a Pinephone keyboard? And did you know that using all the keys on it requires Postmarket OS SXMO installed on it? And does Abiword on the Pinephone make any sense without the Pinephone keyboard and Postmarket OS SXMO?
There is no Keyboard for Pinephone Original, only for Pinephone Pro.
Hi Walter,
Here in the Pine64 shop it says:
https://pine64.com/product/pinephone-pin...oard-case/
PINEPHONE & PINEPHONE PRO KEYBOARD
- Compatible with PinePhone and PinePhone Pro
- it furthermore says:
«Not all mobile OSes support the keyboard case. At launch the keyboard is supported by: postmarketOS, Manjaro Linux, DanctNIX (Arch Linux) and Mobian»
- I have a Pinephone which was shipped with Ubports and it did not worked for me
- Then I flashed postmarketOS on it and it worked, but not the special keys and the function keys.
- As mentioned above the only solution to get those working is as far as I know postmarket OS SXMO
- To have all the keys working is highly desirable for applications like Abiword, Gnumeric and LibreOffice
- Abiword only has 7 sortcut keys, but I do not know if the arrow keys work without Postmarket OS SXMO and additional special keys which are required.
- Gnumeric supports functions keys and also here it is desirable to have all the keys.
- eventually it is worth to have a multi boot setup with a special distro with Abiword, Gnumeric and Libre Office and Postmarket OS SXMO to have all they keys of the Pinephone keyboard.
Greetings,
Peter
  Using Signal on PinePhone in mid-2023? dante404 47 13,686 Yesterday, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,385 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,097 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 499 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,464 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,742 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,096 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 102,838 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,020 11-04-2023, 07:23 PM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,501 10-18-2023, 08:37 AM
Last Post: luppivega
