Dead new PBP?
Hello all!
My PBP arrived today. unfortunately… it appears to be dead on arrival. The power button did nothing. I plugged it in and that didn’t help. I tried holding down the power button. All that I have to go off of is a red LED indicator that comes on when I plug in the charger. Anything I should try? What do I do?
- James
Make a micro SD card with a bootable image. Disable the eMMC. Search here for "dead PBP" or "won't power on", this happens a lot.
Most likely it is working but the software is crashing early.
:wq
[ SRA accepts you ]
(09-28-2023, 11:42 PM)KC9UDX Wrote: Make a micro SD card with a bootable image.  Disable the eMMC.  Search here for "dead PBP" or "won't power on",  this happens a lot.
Thanks for the reply!
Disconnecting the battery and holding down the power button for a bit, disconnecting the eMMC/reconnecting the eMMC/battery did absolutely nothing. Blank screen with no indication anything is happening.
I will try that. I’ll have to use my steam deck since I already lent out my working laptop to my neighbor ?
it's possible the battery arrived depleted. This is another common cause of this behavior, and I've found that often the PBP won't boot at all until it hits a certain level of charge. I've had mine run down several times, where I had to leave it charge for a few hours before I could get it to boot back. up.
(09-29-2023, 09:47 AM)tophneal Wrote: it's possible the battery arrived depleted. This is another common cause of this behavior, and I've found that often the PBP won't boot at all until it hits a certain level of charge. I've had mine run down several times, where I had to leave it charge for a few hours before I could get it to boot back. up.
It’s been hooked up to the wall for hours now. Tried disconnecting/reconnecting the battery/eMMC module and no dice. Trying to boot via SD/USB stick now…
Per @tophneal , if that's your issue, you may need to charge it with USB-C for a while before using the normal charging port. But be careful, do NOT use both at the same time: that can damage the charging circuit.
Else you really need a bootable micro SD card, with the eMMC disabled via the switch.
Keep in mind that the power LED (and the others) are entirely software controlled. Without software actually running and turning them on, you never get any sign of life (except maybe a warm CPU).
:wq
[ SRA accepts you ]
  Dead Pinebook Pro Keyboard Keys calinb 2 1,065 09-02-2023, 12:31 PM
Last Post: calinb
  Need Advice for Wiping eMMC on Dead LCD Pinebook Pro calinb 9 8,318 05-10-2021, 12:49 PM
Last Post: calinb
Exclamation Pinebook Pro dead after dd crmcalls 2 2,852 03-03-2021, 07:57 PM
Last Post: globaltree
Photo My PineBookPro Dead voodooman 2 3,242 09-14-2020, 09:10 AM
Last Post: Tharadash
  PBP nearly dead cs1cjc 5 5,982 06-24-2020, 06:17 AM
  Pinebook Pro totally dead CaiusH 5 5,589 05-16-2020, 10:52 AM
Last Post: Eight Bit
