debugfs: File 'Bluetooth Playback' in directory 'dapm' already present!
Yesterday after the first automatic system upgrade from Release 202304200351 (https://github.com/manjaro-pinephone/pla...2304200351) the system can not load with error message:
debugfs: File 'Bluetooth Capture' in directory 'dapm' already present!
How do you test the updates/ upgrades?
I installed the update three times and crashes with the same error as the author of the topic and the graphical environment cannot be loaded. At the same time, not a single program like a telegram can be installed without updating the system, it is impossible to use it - correct the update please - a question for the developers
(08-08-2023, 05:35 AM)daemonbsd Wrote: I installed the update three times and crashes with the same error as the author of the topic and the graphical environment cannot be loaded. At the same time, not a single program like a telegram can be installed without updating the system, it is impossible to use it - correct the update please - a question for the developers
I also have the same issue
  drivers present, module missing [mt7921u] Ome Ko 0 822 08-26-2023, 12:30 PM
Last Post: Ome Ko
  "No metadata URIs for vendor directory" bug marked solved in 5.27.6 rqkeating 1 1,016 06-19-2023, 11:02 AM
Last Post: rqkeating
