US Mobile...won't support PPP - SOLVED
I posted this in the PinePhone forum by accident.
I am not sure if the PinePhone Pro uses a different modem, i.e. its "stand-alone modem" instead of a "phone modem'.
If you would be kind enough to check my post,
US Mobile, via T-Mobile's "partially compatible" network, won't support Pinephone Pro - https://forum.pine64.org/showthread.php?...#pid118371
I would be grateful.
SOLVED.
PLEASE, SEE THE LINK ABOVE FOR THE SIMPLE FIX.
See your other post
Question T-Mobile and Pinephone Pro in the US jydoxcen 4 982 01-02-2024, 09:08 AM
Last Post: mikehenson
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 1,627 04-30-2023, 05:03 AM
Last Post: diederik
  [Solved] Connect PPP to PC via USB for data transfer ? libresurf 1 1,227 09-20-2022, 12:31 PM
Last Post: libresurf
  No mobile data access on PPP henrythemouse 5 2,985 04-16-2022, 06:40 PM
Last Post: henrythemouse
  PinePhone Pro support for AT&T 4G realrichardsharpe@gmail.com 1 1,503 03-30-2022, 02:57 PM
Last Post: frankt
  Arch linux phosh - no cellular with T-Mobile sim Conjada 14 8,137 02-21-2022, 10:11 PM
Last Post: The3DmaN
