Mobian Boot Problem
(10-15-2023, 12:47 AM)alpopa Wrote: Hi flanders51,
I did not fresh install mobian on PineTab2 recently, however, I regularly update already installed mobian. The first time I succeed, I did the following:
1. Download the latest mobian image (not installer) from https://images.mobian.org/pinetab2/weekly/.
2. Download u-boot from https://gitlab.com/julianfairfax/u-boot-...s/download.
3. Flash the downloaded mobian image to microSD card of at least 8 GB. I use Balena Etcher for this.
4. Mount microSD card, it has 2 partitions: boot and rootfs, both with Ext4 filesystem. Copy u-boot-rockchip-spi.bin from u-boot archive file to boot partition:
-rw-r--r-- 1 root root  4025731 Jul 14 15:35 System.map-6.3-rockchip
-rw-r--r-- 1 root root  220243 Jul 14 15:35 config-6.3-rockchip
drwxr-xr-x 3 root root    1024 Sep  3 03:57 dtb-6.3-rockchip
drwxr-xr-x 2 root root    1024 Sep  3 04:02 extlinux
-rw-r--r-- 1 root root 17242346 Sep  3 04:00 initrd.img-6.3-rockchip
drwx------ 2 root root    12288 Sep  3 03:56 lost+found
-rw-r--r-- 1 root root 1485824 Jul 14 13:20 u-boot-rockchip-spi.bin # This file is manually copied
-rw-r--r-- 1 root root  9793886 Jul 14 15:35 vmlinuz-6.3-rockchip
5. Power off PineTab2, insert microSD card in it and power on. Mobian should be able to boot. Default user is mobian, default password is 1234.
Attention: At the very first boot, the filesystem resizes to actual microSD card size, so it is a bit longer.
Hi alpopa
How many time take the 8GB?, I'm not sure if I did it well. I'm using UART adapter to see logs but I'm not sure if it boot right. So The screen doesn't show anything
DDR V1.18 f366f69a7d typ 23/07/17-15:48:58
ln
LP4/4x derate en, other dram:1x trefi
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=8192MB
tdqss: cs0 dqs0: -24ps, dqs1: -96ps, dqs2: -72ps, dqs3: -192ps,
tdqss: cs1 dqs0: -24ps, dqs1: -96ps, dqs2: -72ps, dqs3: -192ps,
change to: 324MHz
clk skew:0x64
change to: 528MHz
clk skew:0x58
change to: 780MHz
clk skew:0x58
change to: 1056MHz(final freq)
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x3f
cs 0:
the read training result:
DQS0:0x3a, DQS1:0x3e, DQS2:0x41, DQS3:0x37,
min  : 0x9  0xb  0xd  0xa  0x1  0x3  0x7  0x1 , 0x8  0x9  0x2  0x1  0xe  0xb  0xe  0xa ,
      0x11 0x11  0xe  0xd  0x9  0x1  0x3  0x8 , 0xb  0x7  0x7  0x2  0xe  0xd  0x9  0xf ,
mid  :0x28 0x29 0x2b 0x29 0x1e 0x21 0x23 0x1f ,0x27 0x28 0x21 0x20 0x2b 0x2a 0x2c 0x28 ,
      0x2f 0x31 0x2d 0x2b 0x27 0x21 0x23 0x27 ,0x2b 0x27 0x27 0x23 0x2e 0x2e 0x29 0x2f ,
max  :0x47 0x48 0x49 0x48 0x3b 0x3f 0x40 0x3e ,0x46 0x47 0x40 0x40 0x48 0x49 0x4a 0x47 ,
      0x4e 0x51 0x4c 0x4a 0x45 0x42 0x44 0x47 ,0x4b 0x47 0x47 0x44 0x4e 0x4f 0x4a 0x50 ,
range:0x3e 0x3d 0x3c 0x3e 0x3a 0x3c 0x39 0x3d ,0x3e 0x3e 0x3e 0x3f 0x3a 0x3e 0x3c 0x3d ,
      0x3d 0x40 0x3e 0x3d 0x3c 0x41 0x41 0x3f ,0x40 0x40 0x40 0x42 0x40 0x42 0x41 0x41 ,
the write training result:
DQS0:0x3c, DQS1:0x33, DQS2:0x36, DQS3:0x26,
min  :0x5f 0x64 0x64 0x63 0x57 0x5a 0x5d 0x5d 0x5c ,0x54 0x53 0x4e 0x4d 0x57 0x56 0x58 0x56 0x53 ,
      0x5f 0x60 0x5c 0x5c 0x56 0x53 0x55 0x59 0x5a ,0x52 0x50 0x50 0x4d 0x56 0x56 0x52 0x57 0x50 ,
mid  :0x7d 0x80 0x82 0x7f 0x74 0x77 0x7a 0x79 0x79 ,0x71 0x70 0x6b 0x6a 0x74 0x72 0x74 0x72 0x70 ,
      0x7b 0x7c 0x77 0x77 0x72 0x6d 0x70 0x73 0x75 ,0x6d 0x6b 0x6a 0x69 0x72 0x72 0x6d 0x73 0x6b ,
max  :0x9c 0x9d 0xa1 0x9c 0x92 0x94 0x97 0x96 0x97 ,0x8e 0x8e 0x88 0x87 0x92 0x8f 0x90 0x8f 0x8d ,
      0x97 0x98 0x92 0x92 0x8e 0x87 0x8b 0x8e 0x90 ,0x89 0x87 0x85 0x85 0x8f 0x8e 0x89 0x8f 0x87 ,
range:0x3d 0x39 0x3d 0x39 0x3b 0x3a 0x3a 0x39 0x3b ,0x3a 0x3b 0x3a 0x3a 0x3b 0x39 0x38 0x39 0x3a ,
      0x38 0x38 0x36 0x36 0x38 0x34 0x36 0x35 0x36 ,0x37 0x37 0x35 0x38 0x39 0x38 0x37 0x38 0x37 ,
cs 1:
DQS0:0x3d, DQS1:0x3e, DQS2:0x40, DQS3:0x36,
min  : 0xc  0xf  0xf  0xd  0x1  0x5  0x8  0x5 , 0x9  0x8  0x3  0x1  0xb  0xb  0xd  0x9 ,
      0x12 0x11  0xe  0xd  0x9  0x1  0x5  0x7 , 0xa  0x7  0x5  0x1  0xe  0xc  0x9  0xd ,
mid  :0x2b 0x2c 0x2e 0x2b 0x21 0x23 0x27 0x23 ,0x28 0x27 0x22 0x20 0x2a 0x29 0x2c 0x29 ,
      0x30 0x30 0x2d 0x2b 0x27 0x21 0x24 0x27 ,0x29 0x27 0x25 0x21 0x2d 0x2d 0x29 0x2d ,
max  :0x4a 0x4a 0x4d 0x4a 0x41 0x41 0x47 0x42 ,0x47 0x47 0x41 0x3f 0x4a 0x48 0x4b 0x49 ,
      0x4e 0x50 0x4c 0x4a 0x45 0x41 0x44 0x47 ,0x49 0x47 0x46 0x42 0x4d 0x4e 0x49 0x4d ,
range:0x3e 0x3b 0x3e 0x3d 0x40 0x3c 0x3f 0x3d ,0x3e 0x3f 0x3e 0x3e 0x3f 0x3d 0x3e 0x40 ,
      0x3c 0x3f 0x3e 0x3d 0x3c 0x40 0x3f 0x40 ,0x3f 0x40 0x41 0x41 0x3f 0x42 0x40 0x40 ,
min  :0x63 0x66 0x66 0x66 0x59 0x5b 0x5f 0x5e 0x5f ,0x55 0x54 0x50 0x4e 0x58 0x57 0x58 0x56 0x54 ,
      0x5f 0x5f 0x5c 0x5c 0x56 0x53 0x54 0x59 0x5a ,0x50 0x4f 0x4e 0x4b 0x55 0x54 0x50 0x55 0x4e ,
mid  :0x7f 0x80 0x81 0x80 0x75 0x77 0x7a 0x79 0x7a ,0x71 0x70 0x6b 0x6a 0x74 0x72 0x73 0x72 0x6f ,
      0x7b 0x7b 0x77 0x77 0x72 0x6d 0x6f 0x73 0x75 ,0x6c 0x6b 0x69 0x67 0x71 0x70 0x6c 0x71 0x6a ,
max  :0x9b 0x9b 0x9d 0x9b 0x91 0x93 0x96 0x95 0x96 ,0x8d 0x8c 0x86 0x86 0x90 0x8e 0x8e 0x8e 0x8b ,
      0x97 0x98 0x92 0x92 0x8e 0x87 0x8b 0x8e 0x90 ,0x89 0x87 0x84 0x83 0x8d 0x8d 0x88 0x8e 0x86 ,
range:0x38 0x35 0x37 0x35 0x38 0x38 0x37 0x37 0x37 ,0x38 0x38 0x36 0x38 0x38 0x37 0x36 0x38 0x37 ,
      0x38 0x39 0x36 0x36 0x38 0x34 0x37 0x35 0x36 ,0x39 0x38 0x36 0x38 0x38 0x39 0x38 0x39 0x38 ,
CA Training result:
cs:0 min  :0x43 0x3a 0x3a 0x2f 0x3a 0x2f 0x39 ,0x45 0x36 0x3a 0x2a 0x3a 0x2c 0x3c ,
cs:0 mid  :0x7d 0x7e 0x75 0x73 0x74 0x73 0x68 ,0x7d 0x7c 0x72 0x70 0x73 0x71 0x6a ,
cs:0 max  :0xb8 0xc2 0xb0 0xb7 0xaf 0xb7 0x97 ,0xb6 0xc2 0xab 0xb7 0xac 0xb7 0x98 ,
cs:0 range:0x75 0x88 0x76 0x88 0x75 0x88 0x5e ,0x71 0x8c 0x71 0x8d 0x72 0x8b 0x5c ,
cs:1 min  :0x3f 0x40 0x34 0x34 0x35 0x34 0x36 ,0x3e 0x38 0x33 0x2c 0x34 0x2e 0x36 ,
cs:1 mid  :0x7e 0x7f 0x74 0x73 0x74 0x74 0x68 ,0x7a 0x7a 0x6f 0x6d 0x71 0x70 0x65 ,
cs:1 max  :0xbd 0xbe 0xb4 0xb3 0xb3 0xb4 0x9a ,0xb7 0xbc 0xac 0xaf 0xae 0xb3 0x95 ,
cs:1 range:0x7e 0x7e 0x80 0x7f 0x7e 0x80 0x64 ,0x79 0x84 0x79 0x83 0x7a 0x85 0x5f ,
out
U-Boot SPL 2023.07.02-00095-g81dac0348f (Sep 24 2023 - 13:04:24 +0000)
Trying to boot from MMC2
## Checking hash(es) for config config-2 ... OK
## Checking hash(es) for Image atf-1 ... sha256+ OK
## Checking hash(es) for Image u-boot ... sha256+ OK
## Checking hash(es) for Image fdt-2 ... sha256+ OK
## Checking hash(es) for Image atf-2 ... sha256+ OK
## Checking hash(es) for Image atf-3 ... sha256+ OK
## Checking hash(es) for Image atf-4 ... sha256+ OK
## Checking hash(es) for Image atf-5 ... sha256+ OK
## Checking hash(es) for Image atf-6 ... sha256+ OK
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-607-gbf602aff1:cl
NOTICE:  BL31: Built : 10:16:03, Jun  5 2023
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid 220114
INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE wK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2023.07.02-00095-g81dac0348f (Sep 24 2023 - 13:04:24 +0000)
Model: Pine64 PineTab2 v2.0
DRAM:  8 GiB (effective 7.7 GiB)
PMIC:  RK8170 (on=0x80, off=0x04)
Core:  341 devices, 29 uclasses, devicetree: separate
MMC:   mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0
Loading Environment from nowhere... OK
In:    serial@fe660000
Out:   serial@fe660000
Err:   serial@fe660000
Net:   No ethernet found.
Hit any key to stop autoboot:  0
Bus usb@fd000000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fd800000: USB EHCI 1.00
Bus usb@fd840000: USB OHCI 1.0
scanning bus usb@fd000000 for devices... 1 USB Device(s) found
scanning bus usb@fd800000 for devices... 1 USB Device(s) found
scanning bus usb@fd840000 for devices... 2 USB Device(s) found
No ethernet found.
No ethernet found.
Thanks in advance
(11-17-2023, 03:40 PM)genobraker Wrote: How many time take the 8GB?, I'm not sure if I did it well. I'm using UART adapter to see logs but I'm not sure if it boot right. So The screen doesn't show anything
ln
ddrconfig:7
LPDDR4X, 324MHz
change to: 324MHz
clk skew:0x64
change to: 528MHz
clk skew:0x58
change to: 780MHz
clk skew:0x58
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x3f
cs 0:
cs 1:
CA Training result:
out
INFO:    SPSR = 0x3c9
In:    serial@fe660000
USB XHCI 1.10
No ethernet found.
No ethernet found.
Thanks in advance
It might take a few minutes longer depending on the size and speed of your SD card. If you ever resized Ext4 partition on the same media manually, this is best indicator of how much it should take. Sure, it does not take hours.
In your case I see SPL did the job:
Then u-boot tried to do something:
But then it stopped with the prompt =>. So, I see it failed in your case. I can't say much more about why.
This link doesn't work any more
Looking at the repository it is really confusing which one should be downloading here.
Should I then assume that the mobian - roadmap is dead in the waters?
(12-07-2023, 04:52 AM)Corfromleuven Wrote: https://gitlab.com/julianfairfax/u-boot-...s/download
Just followed this link, it is active and downloaded artifacts.zip archive with u-boot (containing 2 files). Mobian is definitely not dead. Maybe it just in process of preparing a new version based on new Debian version.
*IF* you want to use Julian's u-boot artifacts, please get them from  the latest pipeline via https://gitlab.com/julianfairfax/u-boot-.../pipelines
Older versions, like the one that was linked, have issues/bugs which have been fixed in a later commit (and thus pipeline).
  Pine won't boot after last update Corfromleuven 1 304 03-31-2024, 05:21 AM
Last Post: Surehand53
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 2,683 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian won't boot after ton of updates bartgrefte 11 4,834 12-10-2023, 02:47 AM
Last Post: bartgrefte
  Mobian - Phosh frtodd 1 1,241 06-18-2023, 04:51 AM
Last Post: GloriousCoffee
  New images with 6.1 kernel won't boot (mobian / postmarketos) gischpelino 0 962 01-17-2023, 11:36 AM
Last Post: gischpelino
  Booting issue for postmarketos (tow-boot)? olyavi 0 1,035 09-15-2022, 05:38 AM
Last Post: olyavi
  PineTab Mobian bcnaz 150 147,398 04-26-2022, 11:58 AM
Last Post: thomzane
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 4,139 04-30-2021, 06:52 AM
Last Post: thomzane
  PineTab Mobian LXDE desktop fjord 0 2,261 02-24-2021, 06:32 PM
Last Post: fjord
  Pinetab Mobian optimization tomoqv 13 12,655 02-06-2021, 04:36 AM
Last Post: barray
