Moving to trixie
Anyone already using trixie without problems? I want to pass to trixie, but not sure yet if it's the right time. I just saw that phosh 28 pass to testing, so i wanna try it:
https://tracker.debian.org/pkg/phosh
I plan to heed the advise given by the Mobian team if I decide to move to trixie at all. (That would depend on whether it sounds like there are fixes or new features worth trying out, and I'd make a full image backup of the eMMC before proceeding.)
https://blog.mobian.org/posts/2023/06/10/bookworm/
"Important: Be aware that in the weeks following a Debian stable release there is a huge influx of updated packages and big transitions to new versions, clearing the backlog that has been building up during the freeze period. We would advise people to not immediately switch over to the new Trixie/testing distribution. Wait for a few weeks/months until things have calmed down and switch over then, unless you want to live through every breakage that might ensue post-release."
i go trixie after some time, but for short time i'm probably on bookworm. however i have many pinephphones, so one may be on trixie. my guess is that bookworm will be behind than trixie quite soon in features, maybe three months.
I may give trixie a try in a month or two to see if some issues have been fixed, but would do it on an SD card as a test, not my eMMC installation.
Just moved to trixie, all good so far. Phosh 28 is good. All stable been using the whole afternoon the phone.
most secure method is updating to trixie over tor.
sudo apt install apt-transport-tor  tor
make /etc/apt/sources.list look as
#deb http://deb.debian.org/debian trixie main
#deb http://security.debian.org/ trixie-security main
deb tor://2s4yqjx5ul6okpp3f2gaunr2syex5jgbfpfvhxxbbjwnrsvbk5v3qbid.onion/debian trixie main
deb tor://5ajw6aqf3ep7sijnscdzw77t7xq4xjpsy335yb2wiwgouo7yfxtjlmid.onion/debian-security trixie-security main
make /etc/apt/sources.list.d/mobian.list look as
#deb http://repo.mobian.org/ trixie main non-free-firmware
deb tor+https://repo.mobian.org/ trixie main non-free-firmware
then
sudo apt update
then
sudo apt upgrade
then reboot.
How can we trust those TOR links not to contain malware? I would recommend HTTPS instead, failing that HTTP, but not TOR with Onion links given by some random commenter on some forum.
(07-09-2023, 05:41 AM)Kevin Kofler Wrote: How can we trust those TOR links not to contain malware? I would recommend HTTPS instead, failing that HTTP, but not TOR with Onion links given by some random commenter on some forum.
those are official debian tor domains.
https://onion.debian.org/
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,183 Yesterday, 09:27 AM
Last Post: anonymous
  Phoch Trixie weekly install seems nice reTestability 0 201 03-10-2024, 08:47 AM
Last Post: reTestability
  Moving to Tow-Boot: Towards Device-Independant Images user641 9 5,107 04-30-2022, 07:56 PM
Last Post: TRS-80
