Possible to remove LCD from front case?
Question
Had a seal failure on my Pinetime.
Backlight not turning off when the display blanks and flickering when display is on and later some scanlines not drawing correctly.
Cleaning the PCB and screen connector hasn't fixed the problem and the display has started showing dimmer blotches so I figure there must be moisture on the display side.
So is it possible to non-destructively remove the LCD from the front case and if so how?
  Is it possible to hack a UV sensor in the current case? BogdanV 1 2,932 12-25-2020, 08:43 PM
Last Post: barray
