Very slow GbE when receiving, fast sending
I received my Quartz64 a little while ago and have been experimenting a bit. The network is extremely slow when receiving data, but does the usual 940 Mbit/s full saturation for 1 gigabit when sending. Please see below iperf3 outputs. 10.0.0.201 is my Quartz64 model A and 10.0.0.4 is a pretty powerful amd64 Linux workstation.
Server listening on 5201 (test #1)
Accepted connection from 10.0.0.4, port 32952
[  5] local 10.0.0.201 port 5201 connected to 10.0.0.4 port 32954
[ ID] Interval          Transfer    Bitrate
[  5]  0.00-1.00  sec  110 MBytes  926 Mbits/sec
[  5]  1.00-2.00  sec  112 MBytes  941 Mbits/sec
[  5]  2.00-3.00  sec  112 MBytes  941 Mbits/sec
[  5]  3.00-4.00  sec  112 MBytes  941 Mbits/sec
[  5]  4.00-5.00  sec  112 MBytes  942 Mbits/sec
[  5]  5.00-6.00  sec  112 MBytes  941 Mbits/sec
[  5]  6.00-7.00  sec  112 MBytes  941 Mbits/sec
[  5]  7.00-8.00  sec  112 MBytes  941 Mbits/sec
[  5]  8.00-9.00  sec  112 MBytes  941 Mbits/sec
[  5]  9.00-10.00  sec  112 MBytes  941 Mbits/sec
[  5]  10.00-10.00  sec  308 KBytes  885 Mbits/sec
[  5]  0.00-10.00  sec  1.09 GBytes  940 Mbits/sec                  receiver
Server listening on 5201 (test #2)
Accepted connection from 10.0.0.4, port 54688
[  5] local 10.0.0.201 port 5201 connected to 10.0.0.4 port 54704
[ ID] Interval          Transfer    Bitrate        Retr  Cwnd
[  5]  0.00-1.00  sec  1.17 MBytes  9.81 Mbits/sec  41  2.83 KBytes
[  5]  1.00-2.00  sec  827 KBytes  6.78 Mbits/sec  23  2.83 KBytes
[  5]  2.00-3.00  sec  1.37 MBytes  11.5 Mbits/sec  48  2.83 KBytes
[  5]  3.00-4.00  sec  2.42 MBytes  20.3 Mbits/sec  53  2.83 KBytes
[  5]  4.00-5.00  sec  1.24 MBytes  10.4 Mbits/sec  37  2.83 KBytes
[  5]  5.00-6.00  sec  2.25 MBytes  18.9 Mbits/sec  102  2.83 KBytes
[  5]  6.00-7.00  sec  1.12 MBytes  9.42 Mbits/sec  95  2.83 KBytes
[  5]  7.00-8.00  sec  3.08 MBytes  25.9 Mbits/sec  234  2.83 KBytes
[  5]  8.00-9.00  sec  3.11 MBytes  26.1 Mbits/sec  73  2.83 KBytes
[  5]  9.00-10.00  sec  3.48 MBytes  29.2 Mbits/sec  72  2.83 KBytes
[  5]  0.00-10.00  sec  20.1 MBytes  16.8 Mbits/sec  778            sender
Look at all those retransmits! I've verified that the cable and switch port and everything else in the setup are otherwise fine. This happens in both Arch and Plebian. Did I receive a bad board, should I submit an RMA? Or is there something else going on here?
(05-25-2023, 09:51 AM)unixpoet Wrote: I received my Quartz64 a little while ago and have been experimenting a bit. The network is extremely slow when receiving data, but does the usual 940 Mbit/s full saturation for 1 gigabit when sending. Please see below iperf3 outputs. 10.0.0.201 is my Quartz64 model A and 10.0.0.4 is a pretty powerful amd64 Linux workstation.
I have similar problem,
I am able to ping other network devices but the 3 quartz64a I own rarelly respond to ping from other devices.
Can you also try pingin the device for a longer time? Sometimes it responds for a minute and then stops for another minute.
