Pipewire
I removed Pulseaudio and set Pipewire. Sounds work well but the phone
Receive well but with my voice to the other telephone sends a strong noise
Can this be corrected and how?. It is curious that when purge Pulseaudio
automatically loads pipewire. The gnome-sound-recorder is also caput(spoiled)
I'm surprised. After the last Mobian update I have done an autoremove and it has removed quite a bit and: my phone runs clean both ways on both emmc and sd!
I am having this same issue on Manjaro. I'll try the autoremove.
Nope, still a problem. Latest Manjaro, latest master pipewire.
The solution to this seems to be to use pulseaudio for sound. It is possible to keep pipewire around if you need it to run the camera for gnome-snapshot. See tutorial: https://nicholasroth.net/2023/07/09/the-...phone-pro/
  Pipewire Struggle nroth 3 1,630 07-27-2023, 08:12 PM
Last Post: nroth
