No audio on calls after updating today
(12-12-2022, 08:27 PM)Zebulon Walton Wrote:
(12-12-2022, 07:04 PM)BaronAlbatross Wrote: If you have the time, could you spell out your process please? I have an important call tomorrow and I have no time at all to get it wrong and make a bigger mess!
If you're talking about going back to pulseaudio after having moved to pipewire, it was basically a matter of reversing what was done - disable pipewire and re-enable pulseaudio. I had to play around with it a bit but it came down to the following commands run as the normal mobian user:
# Disable pipewire
systemctl --user stop pipewire pipewire.socket pipewire-pulse
systemctl --user disable pipewire pipewire.socket pipewire-pulse
systemctl --user mask pipewire pipewire.socket pipewire-pulse
# Enable pulseaudio
systemctl --user unmask pulseaudio pulseaudio.socket
systemctl --user enable pulseaudio pulseaudio.socket
systemctl --user start pulseaudio pulseaudio.socket
It's a good idea to keep a "known to work" SD card on hand just in case. Don't update it once it's you have it in a workable state. Having that has saved my bacon on a few occasions.
Thank you so much! I think I will make a backup after this, it should have been common sense!
  Bluetooth audio revisited 3x5co 1 1,083 01-10-2023, 05:51 PM
  Ringtones and Audio Modes biketool 0 755 09-05-2022, 10:42 AM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 853 07-17-2022, 10:34 AM
Last Post: 3x5co
  Calls 4G not working oliwierzgorniak 1 1,303 07-04-2022, 05:15 AM
Last Post: zetabeta
  Problem updating gilwood 5 3,306 06-09-2022, 08:27 AM
Last Post: gilwood
  Chrony interrupts calls. jhasler 0 783 04-18-2022, 08:48 PM
Last Post: jhasler
  Bluetooth audio support? Zebulon Walton 5 3,682 02-28-2022, 08:59 AM
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 2,731 02-18-2022, 08:54 AM
Last Post: battlegarden
  Calls : two rings and call cut and restore. Gribouille 0 889 01-14-2022, 07:40 AM
Last Post: Gribouille
  Help! Audio stopped working Barugon 4 3,308 11-03-2021, 10:58 AM
Last Post: Barugon
